Old 12-08-2012, 11:19 AM   #1
jstan
Default 3GX Update - Directions Different Than My Stuff?
I know that I'm directionally challenged... I've just finished my first build a Trex 700e, using 3GX and 2 Sats. I've been able to download 2.1 and begin setup.
I can't seem to figure out how to load 3.0 to the 3GX. I have removed 2.1 from my computer and downloaded 3.0. The directions say to Connect the 3G controller unit to the Y-harness and not to the 3G controller. I seem to only have a single connector (no Y) and only have a 3G controller.
Again, I know that I must be stupid, but this is my first attempt a building/programming. Thanks.
- Jeff
jstan is offline        Reply With Quote
Old 12-08-2012, 12:37 PM   #2
ferebeed
I think you downloaded the 3G not the 3GX. Make sure it says 3GX. Now for the both FBL systems V3.0.
Sent from my iPod touch using Tapatalk
ferebeed is online now        Reply With Quote
Old 12-08-2012, 12:47 PM   #3
ferebeed
Also look at the dates. You want the date to be 12/03/12.
The 3G V3.0 was updated on 11/18/2011. You don't want that one.
Go to news it's on the top of the list
Free 3GX V3.0 upgrade.
It will have a picture of the 3GX.
Old 12-08-2012, 01:04 PM   #4
bad007
http://www.align.com.tw/alignhtml/3gx_update/3gx_update.html
450Pro 3GX HW PL ProV4, Edge KDBB, 500ESP DFC 3GX Edge, 500L MicroBeast Plus HW PL Pro V4 KDBB Blades KST HV, Align 550 DFC MicroBeast Plus, Velocity 50 Vbar 5.3 Pro, OS55 HZ-R, Radix V2 KDBB Castle, D380, MicroBeast Plus Switch Blades
bad007 is online now        Reply With Quote
Old 12-08-2012, 01:32 PM   #5
jstan
Default Ah yes...user error
I had actually downloaded 3G and 3GX...once everything was removed, I made sure to download the 3GX version...It's done. THANKS ALL!
Old 12-08-2012, 01:33 PM   #6
resqjock
What do I do after I D/L the firmware, I have done a firmware update on 3GX
Align Trex: 450PRO FBL w/3GX, 500PRO FBL w/CGY-750, 600PRO FBL w/CGY-750
Futaba 8FG, Spektrum DX8
MCPx, Nano CPx, MQx
resqjock is offline        Reply With Quote
Old 12-08-2012, 01:47 PM   #7
bad007
After you install 3.0 in the PC and update the firmware in the 3GX just launch the software and follow the directions.
Old 12-09-2012, 06:56 AM   #8
Generalx5
Go to the very last tab. Skip the setting up, the last tab to the right is a firmware tab. Under that page is where you can update 2.1 to 3.0
When you pick the firmware file. The default location is already set. Just click highlight the 3GX_v3.0.exe file and your set. Cheers
Generalx5 is offline        Reply With Quote
