Old 12-08-2012, 01:15 PM   #1
fourbie
Default Filling with nitro
How do you fill your tank?
Do you have a T piece near the carb inlet.
Do you not have a T piece and just pull the tube.
Do you fill from the muffler side?
Have a great day - John
"Do it to them before they do it to you" {Hill Street Blues}
When the blue light is flashing I am kidding. E&OE.
fourbie is offline        Reply With Quote
Old 12-08-2012, 01:28 PM   #2
McKrackin
I pull the line off the carb to fill.
Nice clean look.
All my filters are in my fuel jug so no filter on the heli.
McKrackin is offline        Reply With Quote
Old 12-08-2012, 01:35 PM   #3
rcflier1
i pull the line off my tank. filter in the can and fllter in the line to the carb
rcflier1 is offline        Reply With Quote
Old 12-09-2012, 08:58 AM   #4
j bomb
I use a T-style filter in the line to the carb w/ a short piece of tubing, plugged at the end. Just pinch the line below the carb and pull the plug to fill the tank.
John Barta
Michigan Whirlybirds Heli Club
j bomb is online now        Reply With Quote
Old 12-09-2012, 10:09 AM   #5
fourbie
No one yet fills from the muffler side then!!
Old 12-09-2012, 10:43 AM   #6
Elgyn
I would but the laws of physics say no. Although it is very good at filling the motor
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP
Elgyn is offline        Reply With Quote
Old 12-09-2012, 11:16 AM   #7
McKrackin
Sounds like you have no understanding of the comment.
Pull the fuel line off the muffler and fill the tank...The fuel line goes to the tank...not the engine.
Old 12-09-2012, 11:58 AM   #8
fourbie
Yes - I personally don't do it this way but have come across it twice recently and the method quite surprised me.
Also, in general I don't like pulling tubes off the barbs on filters.
Old 12-09-2012, 02:31 PM   #9
McKrackin
The barbs won't hurt anything but what will is the heat on the muffler.
The heat makes the fuel line brittle and pulling it off the muffler repeatedly will wear it out 100X faster than anywhere else.
Old 12-09-2012, 09:25 PM   #10
koppterx
muffler - not to mention that it hurts like hell if you touch it and leaves a nice blister. makes no sense to me to have anythng going on on the muffler side. i use a t.
converting nitro into noise since the 70's.
koppterx is online now        Reply With Quote
Old 12-10-2012, 12:31 AM   #11
Elgyn
I'm trying to figure out if you have a three line tank or have never tried it to see what happens... ...I'm going with the latter because very few heli’s have a 3 line. I'll explain it.
Fuel goes into the tank and goes to the lowest part of the tank where the pick-up is also located. Since the fuel is being pushed in it want to find a way out which happens to be the pick-up that also at the lowest point in the tank. Henceforth out the pick up into the engine (or header tank and the same thing happen but in a smaller scale). Very little actually stays in the tank.
Or, if there's enough back pressure from the motor and the pump is strong enough then it blows a line off.
Old 12-10-2012, 12:35 AM   #12
jhunter
I've always used a t connector except on kasama because they have a built in separate line for fuel but I also use an in line filter. That is a must I think, especially if you use a fuel magnet. In case it deteriorated and went straight to the motor.
TDR, Srimok N x 2, Banshee 31, avant aurora, Dune!
jhunter is offline        Reply With Quote
Old 12-10-2012, 05:22 PM   #13
Jafa
We always fill from the inlet side because as you fill the tank with fuel the air has to be vented out through the muffler line
Gryphon field rep
Jafa is offline        Reply With Quote
Old 12-10-2012, 05:43 PM   #14
fourbie
[Fuel goes into the tank and goes to the lowest part of the tank where the pick-up is also located. Since the fuel is being pushed in it want to find a way out which happens to be the pick-up that also at the lowest point in the tank. Henceforth out the pick up into the engine (or header tank and the same thing happen but in a smaller scale). Very little actually stays in the tank.
I have a fuel clamp on my tube near the carb so no fuel would get to the engine.
Good point.
Old 12-10-2012, 05:43 PM   #15
McKrackin
Actually...I was just curious about what my foot tastes like
Old 12-16-2012, 01:06 AM   #16
Cra-Z-1
I prefer spider webs.
I pull the vent line plug, so all the residue sprays down; then pull the fill plug.
Cra-Z-1 is offline        Reply With Quote
