| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
#21 | |
As for the swash leveler, it works fine. Just levels the top of the swash which is not what needs to be leveled. You want to level the top of the servo balls. But its close enough. Doesn't matter. In the end, the blades need to track right. You will have to use some trim to get there. Swash leveler is the best starting point you are going to get.
Mini Prôtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready |
#22 |
Who said the swash to grip lengths would be 17 between the plastic links, I sure did NOT ?? They need to be whatever they need to be. Just for kicks I just measured mine and they are 21.05mm between the plastic links!!
#23 |
lol.. No, you did not. You didn't specifically say that you were talking about servo to swash either lol. I thought 17 servo to swash was self evident. Like you sead, puts the anti rotation pin in the middle of the bracket. Keeps the swash low on the main shaft.
#24 |
Ha! Too funny! Yes Scott, I used the SK setup to center servos and get them as close to 90 as I could eyeball before attaching them to the frame. So do my best to center swash with leveler by adjusting links, and fine tune with servo trim in SK setup. Got it. Same method for leveling swash at low and high stick as well I assume?
Mini Prôtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready Mini Prôtos 6S - DS92A+/DS95i, SK540, YGE60 |
#25 | |
#26 |
You can;t change the link length to adjust it at top and bottom if you used it to level it at center because then it will be oiff at center. The links have to remain one length for all three setups.
#27 |
You do not change link length ! With a flybar head you would adjust your travels (endpoints, atv's etc) to level at high and low collective. As I said some fbl units have a dedicated function to do this. V-bar for sure and pretty sure skookum. Changing travels with fbl will not do squat in this application. The gyros are gonna take care of any unlevelness at high and low because they will sense an uncommanded movement. This is why not all fbl units have this function in there set up modes. A properly done set up with good servos usually wont need any adjustment anyways. Your servo arms would have to be WAY off to have a detrimental difference in the swash high and low.
