Old 12-09-2012, 03:44 PM   #1
Trader
Default Pyro Motors & Logo 600 SX
Hi!
What kind of Pyro motor (Pyro 700-520 or 700-450) do you suggest to buy for 12s LOGO 600 SX?
What is the best pyro's shaft size(may be Long shaft)?
Thanx,
Laci
Trader is offline        Reply With Quote
Old 12-09-2012, 04:13 PM   #2
dahld
For 12S the 450kv motor is more appropriate. And get the long shaft version, as it is needed for the use with the counter bearing.
(-: Dave
Kyle Dahl
Sponsored by:
Mikado, JR, Voltz/Thor, Scorpion, Edge Blades.
dahld is offline        Reply With Quote
Old 12-10-2012, 02:59 AM   #3
bavci_0655
Counter bearing needs 34mm shaft. Pyro 700-52M has 32mm shaft. Long shaft version will be better but you have to cut the extra lenght to protect your lipos.
T-REX 600 EX [ Pyro 700-52M | Scorpion Commander V 130A OPTO | VBar 5.3 Pro | BLS255HV & BLS256HV ]
LOGO 600 SX
[ HKII-4225-500KV | Scorp. Commander VI 130A OPTO | VBar 5.3 Pro | BLS255HV & BLS256HV ]
bavci_0655 is offline        Reply With Quote
Old 12-10-2012, 04:03 AM   #4
Kalpazan
bavci, this is what Mikado says about CB upgrade:
"Important note: This upgrade set works only in connection with a motor shaft 6mm x 32mm long."
Where did you see that 34mm shaft ?
LOGO 400SE: ICE75, 500MX, DS510M+DS650, VBAR 5.3 PRO, EDGE 473, KBDD 72.5
LOGO 600SX: JIVE 100LV, HKIII-4025-1100, BLS451+BLS251, VBAR 5.3 PRO, EDGE 600, EDGE 95
Kalpazan is online now        Reply With Quote
Old 12-10-2012, 07:59 AM   #5
bavci_0655
I think 32mm is for old counterbearing. With new maingear and pinion, lenght of counterbearing is increased. I measured my motors (HKII-4225-500KV) shaft and it is 34mm. It fits perfect on counterbearing.
LOGO 600 SX
Old 12-10-2012, 11:20 AM   #6
Kalpazan
I got the info from here:
http://shop.mikado-heli.de/LOGO-600-...&c=6573&p=6573
Old 12-10-2012, 11:51 AM   #7
mkovalcson
Fingers crossed that the stock 32mm shaft fits well, as that would mean I could exchange motors with my TDR and get a Pyro 750 for my TDR
Hopefully Mikado has this correct on their website..
Henseleit TDR, Synergy E5, MSH PROTOS 500, 130X
Jeti DS-16, Skookum SK-GPS
mkovalcson is offline        Reply With Quote
Old 12-10-2012, 12:39 PM   #8
bavci_0655
32mm will work but it will not completely seat in the bearing. I can attach a picture if you want.
LOGO 600 SX
Old 12-11-2012, 05:56 AM   #9
Jays200
I have the 700-45 long shaft with 12T. yes I had to cut 4-5 mm off the shaft.
78% for 2240HS with Helijive.
Regards, Jayson
Logo Xxtreme 800 Silverline, Pyro 800-40L, Kosmik 200A, 14S, 157 & 256 @ 8v
Logo 600SX, Silverline, Pyro 700-45L, Helijive, 12S, 272 & 256 @ 6v, 623, 105
Logo 400SE Mini Vbar, Mini Pyro 20-08, Jive 80+HV, 6S, 9660A+ 8900G @ 6v
Jays200 is offline        Reply With Quote
Old 12-11-2012, 06:59 AM   #10
Kalpazan
bavci, I believe you. But I recall I measured 32mm on my 4025-1100 and it seated fully into the CB so I wonder why it is not the same for you. Do you happen to use any shims ?
Old 12-11-2012, 08:15 AM   #11
bavci_0655
No shims. Maybe I measured wrong. But counterbearing design changed due to thicker main gear and pinion. I looked at your pictures and my motor shaft is a little out of counterbearing, it is not like yours. So probably you are right.
LOGO 600 SX
Old 12-11-2012, 10:02 AM   #12
Kalpazan
So, 32mm minimum but 34mm recommended
Old 12-11-2012, 10:11 AM   #13
bavci_0655
Yes, you are right.
LOGO 600 SX
Old 12-21-2012, 08:13 PM   #14
Trader
Do you have any experience with Pyro 700-520 & 12S & 600SX setup?
Thanx,
Laci
Old 12-22-2012, 05:24 AM   #15
TommyBear
Make sure you Order the long shaft version of the pyro 52. Perfect fitment for the SX third counter bearing. You will need to order the 11t mode 1 pinion as well.
Silverline VBAR 5.3 PRO : TDRs - LOGO 700 XXTREME 600SX 600SE - Whiplash - FAIFA SRIMOK
TommyBear is offline        Reply With Quote
Old 12-22-2012, 06:16 AM   #16
Trader
Hello TommyBear!
Do you use this Pyro 700-52 in your Logo600SX with 11t on 12s setup?
I could buy this kind of new Pyro 700-52LS motor in good price for my LOGO 600sx, but lot of people suggest Pyro 700-45LS in 12s setup....
Thanx,
Laci
Old 12-22-2012, 07:34 AM   #17
TommyBear
Yes I used the pyro 52 on my SX and the pyro 45 on my SE.
Old 12-22-2012, 10:59 AM   #18
bavci_0655
Originally Posted by Trader View Post
Hello TommyBear!
Thanx,
Laci
There are some threads on this forum that people have gear stripping with this combo. I will suggest 12T with 700-45 motor. Main gear has more contact with this pinion. With lower KV, you will have less headspeed, but you don't need high headspeeds with a Logo.
LOGO 600 SX
Old 12-22-2012, 01:10 PM   #19
Trader
Thank You For Your answers!
I am going to buy motor SOMEWHERE between 450-500 KV!
Peace,
Laci
Old 12-22-2012, 08:27 PM   #20
TommyBear
Incorrect Meshing is what causes gear to strip. Never had a gear strip on my 11t pyro 52 jive Gov logos.
You should be able to run a 200 gsm paper between the gears without ripping. It is in the Mikado logo 600 3D manual.
With the SX 14mm main gear and pinion, it will be much harder to strip gears.
