| Warp 360 Compass Warp 360 Model Helicopter Discussion |
#61 | |
X5, DX7se
My son Enzo's - X5, mcpxBL, DX7se |
#62 |
This might be what you are after:
http://www.bocabearings.com/search.a...fSearchResults I've not finished my build yet, but it seems I may go the ceramic route while I'm still in the process. The link above has seven choices that should work. Not sure about the ones with rubber seals in heli applications, but they list the 'YS' rubber seal as a heli application bearing. Really adds to the build cost, but for the tail bearings at least I'm thinking it is well worth it. |
#63 |
Just purchased on ebay..they were "Associated 4x8x3 ceramic bearings" ..if you do a search..find many available.. I payed 10.00 for the pair..great price..and they are performing very well..very low vibes..on sk720.
#64 |
So I went to my LHS to look for the Associated Bearings but ended up with these Boca's for cheaper. Score!
X5, DX7se
#65 |
What happened to the bearing in pieces?
#66 |
Are those rubber seals? More drag that conventional seals?
#67 |
Exploded in flight. That is what is left. If you hear a high pitch noise coming from your tail, that is probably it.
X5, DX7se
#68 |
#69 |
What specific ceramic bearings?
On the iPad again, JCL |
#70 |
I don't know the specific model number but if you find a "flanged 4x8x3 ceramic bearing" should do the trick. The Team Assiciated ones has a metal seal, I guess the ones I got are rubber. This is my first "boca" bearing. I heard they are pretty good.
X5, DX7se
#71 |
Does anyone know if the 18t motor pinion(pulley) is still unusable like reported due to it hitting the idle pulley?
thanks |
#72 |
That's correct.
Compass Model | KBDD | MKS Servo | running Beast X and Airtronics |
#73 |
How'd that slip through?
Scott Compass 7Hv - Synergy E5 - Logo 600RCHeliCanada.com -Rep Next: 6Hv Ultimate |
#74 |
No idea, perhaps rushed. I hear it will be remedied soon, for anyone really needing that size.
#75 |
16T still the smallest pinion available?
Team Newb Walkera Mini cp - hp06v2, hp02t, custom fet esc's, 550's Blade 130X - hp08s, lots of bling; Blade 130X - ta955, xp12a Compass Warp 360 - CC ice lite 50, MKS DS92A+, iKon |
#76 |
With the prototype motor being higher kv (Jeff is running it @ 4000 on stock pinion!) I imagine no one even had a thought of putting the 18t motor pulley on
130X stock | T-Rex 450PRO v2, AR7200BX | T-Rex 500PRO DFC, HC3-SX | Warp 360, HC3-SX | AMA member |
#77 |
Keep an eye on your tr arm that connects to boom and that your tr lever pitch arm connects to. Inspect regularly for small fractures or cracks. It's not best plastic and can fail. IMO it should be metal of course as should tr pulley. Have fun.
#78 |
+1 , should be metal . Can break and lever pich arm took on boom and block the tail . Must be fixed quickly
#79 |
Thanks Shawn.
Please keep an eye on this part folks. They're actually testing a few different new compounds for this, including a compound similar to what Mikado uses for their frames. They won't make it in CNC aluminum because production costs are too high due to the complexity of the part and the weight, I'm told.
Owner - RCHeliCanada.com Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
#80 | |
Re. plastics, I haven't owned a Logo for about 8 years or so but don't recall the plastic being anything special back then. If Compass wants to see what excellent plastics look like, go take a look at a cheap Hirobo kit. Their plastics will break in a crash (probably because it's quite rigid) but it's really an incredible product, at least the Evo I had a few years ago had great plastic parts. Precision molding, excellent finish quality, and VERY stiff. |
