| Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
V-BAR Guru
New video
Gone fishing.. or hunting or something.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
So does the 700 combo come with a "Mikado" YGE, or a standard one?
Mine looks like the standard one in your video with the short cable and then came with an extension. Which settings are "locked" in the Mikado version? |
V-BAR Guru
Mikado version, ok they have an extension now, there is a few diffrent versions there.
Endpoints are locked and you cannot use internal gov
Well done as always fredrik!
#6 |
Thank you, MrMel.
#7 |
V-BAR Guru
Most welcome!
#8 |
I have a Logo 700 with the YGE ESE on it.
When the system is powered on and throttle hold is on the motor is in a semi break mode. Other then that it seems to be working fine. I can set Norm , st1 and St2 to different head speeds etc. I did notice that I can't do stick programming . Is this due to it being the Mikado OEM version? Thanks |
#9 |
Is the Mikado OEM version usable without Vbar gov?
Team Thunder Tiger Europe 4RC.nl, Edge rotorblades, Scorpion systems To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 |
I don't believe so. The internal gov is disabled.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team Insane Canopy |
#11 |
This is kind of confusing, accordingly to http://shop.mikado-heli.de/LOGO-700-...&c=6487&p=6487 it doesn't have an OEM software version. I hope the separate ESC is programmable for its internal governor.
#12 |
The Mikado OEM just has the internal gov locked out I have been told. You do not set end points either with it as they are already done.
You can change timing and pwm frequency. If you want to run anything other than vgov than don't get the Mikado version...
