Old 12-11-2012, 09:12 PM   #1
ROGER G
Default Canopy Air Inlet
I KNOW this is very obvious and simple, but up till now never tried it because I didn't want to do anything to my Protos canopy. I added a small air inlet right under the nose of the canopy, about 1/2 in. wide X 3/4 in. long oval, with a dremel tool. I got to tell you, I was surprised how much cooler the Batt. , ESC, AND motor felt. It's been mentioned here many times before, but I guess I never paid that much attention to the advice or maybe didn't believe it. In any event, I just wanted to post, to let others know that tiny air inlet really works. I will now pay more attention to advice given in this forum.
Roger
ROGER G is offline        Reply With Quote
Old 12-12-2012, 12:04 AM   #2
Dr. M
Yes indeed
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is online now        Reply With Quote
Old 12-12-2012, 07:15 AM   #3
rossk
I need to do this, the other weekend the stock Protos was giving temp warnings after each pack and cut out once too.
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp
MA Whiplash - Kosmik 200, Pyro 700
Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360
MSH Brain Spektrum DX8
rossk is offline        Reply With Quote
Old 12-12-2012, 09:48 AM   #4
Trini92
Can you post a pic of canopy. I may do this too although never really had a temp problem but why not keep things cooler.
Trini92 is offline        Reply With Quote
Old 12-12-2012, 10:52 AM   #5
ROGER G
Sorry, right now all I have to to be on HF is my iPhone and I know of no way to post a pic from it on HF. I'm sure others have done this inlet and can post their pics from a regular computer. By the way, the main reason I did the inlet is because I have the ESC below the Batt. and it is about as far toward as you can get inside the canopy and saw no way their could be any air circulation at all. I figured that could not be good.
Old 12-12-2012, 03:28 PM   #6
rossk
Tapatalk!
I actually prefer my phone over the pc now for forums
Old 12-12-2012, 04:44 PM   #7
ROGER G
TapTalk. Cool. ThanksClick image for larger version
ID:	373645Click image for larger version
ID:	373646Click image for larger version
Old 12-14-2012, 01:58 PM   #8
th0rg0d
How do you protect the paint while cutting?
Mini Prôtos AR7200BX
Prôtos stretch AR7200BX Savöx 1250/1290MG SAB 470mm
ALeeS Rush 750 YGE 120HV/4035-530 AR7200BX Savöx 1258/1290MG Rail 696/116
mCPx stretch uHeli head DX18 AMA# 448427
th0rg0d is offline        Reply With Quote
Old 12-14-2012, 02:26 PM   #9
ROGER G
I didn't ' cut ' but instead used the CONE shape grinding tool that came with the Dremel. It goes thru the thin fiberglass like butter. Very easy with that tool. Also, I should have mentioned, the Nerf ball on a stick pic's is what I use so my Protos canopy won't get blown off the table at the field or pick up table rash. Just mentioned if someone did not know.
Roger
Last edited by ROGER G; 12-14-2012 at 02:41 PM.. Reason: Oh Darn, should have posted a pick of that cone shape tool. Forgot I have TapaTalk now.
Old 12-14-2012, 03:31 PM   #10
whisperdancer
Don't forget to seal the edges with CA after cutting the vent. It prevents the paint from chipping off.
MSH Prôtos CF FBL Stretch - Scorpion 880KV, YGE 60A, 3x s9650, BLS251, VBar 5.1
E-flite HABU 32
Ikarus EXTRemA 330S
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote
Old 12-14-2012, 05:24 PM   #11
th0rg0d
Thanks for the info. I'm going to do it. Keeping it cool can only be better.
Old 12-15-2012, 03:06 PM   #12
Trini92
THanks for the pic and tips.
