Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 12-12-2012, 03:03 AM   #1
Diviner
Default Warp Modopoluza #1 - the CG fix.
I am using GA1200 packs that weigh 175g. Plus I am adding a custom tail that add 3g on the end, which needs about 10g of counterweight. And I am using a very light esc (the flux capacitor, which has a close resemblance to a CC 50 light ).
Needless to say, I am a bit tail heavy.
The quick fix.
1) respot the canopy grommets back 1".
2) make a longer canopy hold down on the belly
3) Trim some of the metal off the front metal standoff.
I first made a prototype out of some easy to cut plexi.
Checked different batteries (175g and 250g).
Made some changes.
Cut the final pieces.
After painting the new skids (Santa's Sleigh), battery tray extender, tail fin, cano hold down, I had a final product . . . almost.
The picture doesn't have the new grommet holes cut yet. I have some new blank canos coming in and they don't have any holes so I will cut them in exactly where I need them.
I also did a keychain mode with breakaway tabs. SOP on all my helis.
ID:	373423   Click image for larger version
ID:	373424   Click image for larger version
ID:	373425   Click image for larger version
ID:	373426   Click image for larger version
ID:	373428   Click image for larger version
6hv, 6hv, 7hv, X5, T500, Warp, 300x powered by the FLUX CAPACITOR
Diviner is online now        Reply With Quote
Old 12-12-2012, 04:40 AM   #2
Luigi_tuga
AHAH! Santa skids!
That is a fresh design
Warp 360 , Tarot 480
T500Fbl AP
MCPX bl PZ StrykerQ DX8
Luigi_tuga is offline        Reply With Quote
Old 12-12-2012, 07:16 AM   #3
Bob O
Wow, some people definitely have talent........nice!!
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 12-12-2012, 08:21 AM   #4
Jeff_Barrett
Yeah, I'm starting to think I need to extend my battery tray and move my canopy to accommodate my WR Super Mini Bec G2 ... I'm having a real hard time finding a home for it under the canopy and still being able to get the canopy on.
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now        Reply With Quote
Old 12-12-2012, 10:39 AM   #5
ScotY
That's cool! You have a laser cutter in your shop?
ScotY is offline        Reply With Quote
Old 12-12-2012, 11:22 AM   #6
Diviner
Yes, but it is not the preferred method for cutting. Those 5 pieces took 1.5 hours of cutting. My laser tubes are getting tired. A cnc would have it cut in minutes and could handle CF.
Old 12-21-2012, 08:46 PM   #7
Diviner
Default Warp Modopoluza #2 pulley/pinion fix, CGv2, bling
I run a castle ice 50, and when set rpm is enabled, they require more pinion than most esc's. The photos below show a castle at 18t and a yge at 16t learned at 4.0v. They are very similar.
So I put in an 18t pinion. The pinion is 1.3mm larger in dia than the stock 16t. Now let it be said that 16t will probably be fine if I had a yge or kontronic. But I have an CC ice 50 lite. Note: the 17t pinion also has a larger diameter than stock.
After installation I discovered it pressed against the upper pulley.
I contacted Nankin, and of course they were great and got one out. The easy fix is to just flip the assembly so the motor doesn't use the counter bearing, and offset the motor mount. But I think the counter bearing is an excellent design feature. I am guessing that this pulley is a part on another compass heli, maybe the 6hv.
So I ground down the pulley 2mm from 15mm to 13mm. That left plenty of material for the motor belt to use.
Before:
Took off the burs and and it was good to go.
After:
Next was the battery cg issue. I had the GA 1200 which weighed 175g. I got the cg resolved, but the battery stuck out too much. That pushed the canopy out and since the canopy tapers in (another great design feature), I had to extend my key chain bushings.
I ordered some green pulses which actually weigh in at 258g with connectors. Helidirect specs says it weighs 220g . . . NOT! Very similar to the GA1400's which I have been told will be here next season ( I asked on FB). So if you want GA 1400's and don't want to wait, the green pulses 1350 sure spec out very similar to the GA's.
After playing with the CG, I removed the custom battery extension tray and the cano extension. I put on 62mm blades rather than the 70mm ones I had one (thanks Mr. Barret for the idea!). That saved some weight. So I added 80g of battery weight (but added 150mah), and removed 60g of "stuff" (tail fin, battery extension tray, cano hold down). So net net, I added 20 grams and gained 150 mah. . . and got my cg more towards center . . . and pushed my cano in . . .. which gave more clearance from the gears . . . . because the canopy tapers in.
I added some velcro to the bottom of the batteries and they function as my cano hold down now. A put a pink foam spacer in so cg would be exact every time.
Funny. Look at the snapshot from the website and look at it mounted in the pic below. Doesn't it seem that the real thing is longer? More evidence that it is perhaps the GA1400.
This let me push my cano back, and I could trim some of the key chain bushings in the process.
Added some more metallic bling.
Next up, the custom cano.
ID:	376052   Click image for larger version
ID:	376053   Click image for larger version
ID:	376056   Click image for larger version
ID:	376058   Click image for larger version
ID:	376060   Click image for larger version
ID:	376061   Click image for larger version
ID:	376062   Click image for larger version
ID:	376063   Click image for larger version
Old 12-21-2012, 08:51 PM   #8
Luvmyhelis
This is some astounding work. Any way you can tailor this into the mod thread Mods? This deserves its spot!
Luvmyhelis is offline        Reply With Quote
Old 12-21-2012, 09:37 PM   #9
Diviner
I will, I just want confirmation when I get the new pulley that it is indeed still 15mm. dia.
Old 12-21-2012, 10:00 PM   #10
Bob O
Nice idea and job with grinding the pulley down to a smaller diameter.
Old 12-31-2012, 12:44 PM   #11
Diviner
Warp cano blanks in da house. Just in time.
Name:	blank canos.JPG
Old 12-31-2012, 05:27 PM   #12
Luvmyhelis
Holy snikes batman! Immensely cool thread! And all those canopies leave me drooling! I haven't even had time to finish up my first custom blank yet.
Old 01-12-2013, 10:36 AM   #13
Diviner
Canos are done.
The CG is perfect. In fact, it's the best piroing heli I have. This has motivated me to get all the other helis CG perfect.
But even with cc 3150 gov and 18t pinion, the headspeed is still too slow for the weight (1080g). I will try a new esc to get around 3300 gov'd.
Also made a TFP cano scheme for phoenix.
ID:	383080   Click image for larger version
Name:	All Canos.JPG
Old 01-12-2013, 10:46 AM   #14
Bob O
Wow, very nice looking canopies!!
Old 01-16-2013, 04:16 PM   #15
Andyzboy
Serious ingenuity! I like it
Andy Cardinal
Compass Models
Gens Ace/Hobbypartz
7HV, Warp 360
Andyzboy is offline        Reply With Quote
Old 04-25-2013, 03:46 PM   #16
Diviner
There are little gullies where I fly that can cause tips with the Warp. So after a little experimentation, I widened the skid distance with .5" bushings and 30mm 2.5 screws. So now the skids are 1" wider.
ID:	415442   Click image for larger version
Old 04-25-2013, 03:58 PM   #17
Ah Clem
OUTSTANDING DIVINER!
KBDD-Team Pilot
Team Compass / ProStar Hobby
Gens Ace Field Representative
Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50
