Old 12-12-2012, 08:30 PM   #1
maarset
Default Static????
Been flying my mini for a week now with no issues. Been flying awesome.
Today first pack got a couple tail twitches. Came in to hover around and got some cyclic twitches and a couple tail twitches. Them motor briefly died and came back on. Did this for three different packs.
I'm starting to get some "Satellite data framing error" errors in vbar log now.
Weather was nice but lots of big thunder clouds near by.
Am I getting static hits?
Anyone ever get static hits on a mini p? Should I ground the boom to the motor mount?
Mike.
Logo 500 VBAR GOV/YGE
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
maarset is offline        Reply With Quote
Old 12-13-2012, 01:38 AM   #2
baui2000
How many sats do you use? This may be related to a loose cable or problem with a connector. I had similar issue with my mini on Spektrum, but it was always related to TX-RX link, never to static.
The mini is conductive from one end to another, so unless there's something wrong, static won't be an issue. You can check by multimeter just to be sure.
Tom
Outrage Fusion 50
HC3-SX, A50-10L Turnado, CC ICE2 120HV, WR Super BEC, DH20-FTD / MKS HBL980
Prôtos Mini FBL Stretch 4S vBar 5.3Pro, MSH 2010kV, YGE-60A, MKS DS95 / DS95i
baui2000 is offline        Reply With Quote
Old 12-13-2012, 02:03 AM   #3
maarset
I use one sat and I use shoo goo on the connector. How is it conductive from one end to the other when the boom is coated and the boom block is plastic?
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
Old 12-13-2012, 07:17 AM   #4
nynextel88
Each end of the boom is not painted. Static shouldn't be an issue
Team HeliProz
Team HAIYIN batteries
Team Lynx
RCGalore
nynextel88 is online now        Reply With Quote
Old 12-13-2012, 09:48 AM   #5
maarset
Ok sounds good. Doing research on the vbar error ""Satellite data framing error"", I find it is either Static, or a phase wire on the motor is grounding. I checked the motor and it is fine. So I'm thinking static or excessive noise. To be on the safe side I grounded the boom to the motor mount
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
Old 12-13-2012, 04:58 PM   #6
desertstalker
No coating on the ends of the boom, and the "plastic" is CFRP, it has a significant amount of carbon fibre in it (short lengths) and is actually somewhat conductive (especially at high voltage) enough so that static is not an issue.
Some though have reported that using the AL rear guide pulley (next to the tail pulley) causes static issues that going back to plastic has corrected.
Considering the weather in the area, the problem could actually have been caused by electrical activity in the clouds, or a static buildup on the whole heli. The humid weather typically associated with electrical storms makes it harder for the belt to cause static problems.
-DX8
Old 12-13-2012, 08:51 PM   #7
maarset
Thanks everyone for the info. I did ground the boom to the motor mount and did 3 flights today with no twitches. I agree it was probably the weather.
I understand now how the design of the mini prevents static.
For piece of mind I'll probably keep the ground wire on.
Mike
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
Old 12-13-2012, 09:07 PM   #8
th0rg0d
This isn't always the case. I just replaced my boom, and had to sand the tail end. Double check your boom.
My Prôtos had tail twitches, so I grounded the boom. After I eventually crashed, I realized the stock boom wasn't sanded. So now I check both the Mini and the 500.
Mini Prôtos AR7200BX
Prôtos stretch AR7200BX Savöx 1250/1290MG SAB 470mm
ALeeS Rush 750 YGE 120HV/4035-530 AR7200BX Savöx 1258/1290MG Rail 696/116
mCPx stretch uHeli head DX18 AMA# 448427
th0rg0d is online now        Reply With Quote
Old 12-13-2012, 11:10 PM   #9
nynextel88
Well with the 1 stock boom i have, and 3 stretched spares they are all bare on the ends. You must of gotten a fluke.
Team HeliProz
Team Lynx
RCGalore
Old 12-14-2012, 04:32 AM   #10
desertstalker
Or really old stock, afaik the first ones were painted at one end.
-DX8
Old 12-14-2012, 10:26 AM   #11
maarset
had to replace my boom a couple weeks ago cause of a faulty Align 415 servo. I believe the part of the boom that went into the boom block was bare metal.
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
Old 02-08-2013, 03:25 PM   #12
maarset
Thought I would update this thread. I couldn't figure out why I had to run a wire from my boom to the motor mount to keep the static hits under control.
It seemed that the mini was specifically designed to handle static.
But it dawned on me that I have after market frames and I believe they are FG.
MSH mini-p VBAR
mcpX V2
mikeaarset.zxq.net
