Old 12-13-2012, 05:39 AM   #1
thomascoleman
Default Powerlab 8 v2 leads
instead of using this to connect to my PSU
Can i use this ?
http://www.fast-lad.co.uk/store/dyn5...na-p-8013.html
DX18 | Goblin 700 Comp LTD-E BeastX Plus | T-Rex 700N PRO DFC AR7200BX | T-Rex 600N PRO DFC AR7200BX | Logo 480XGPRO | 300 CFX |
thomascoleman is offline        Reply With Quote
Old 12-13-2012, 10:06 AM   #2
jdd1
Can i use this ?
Hi Thomas,
Yes, if the male banana plugs are rated at 60 amps @ 24 volts; that is if you want or need to run the PL8 at full capacity. I have seen the plastic housing around the banana plugs melt under high current demands. Just verify the bananas are rated up to 60 amps.
Jack
Jack Doherty
FMA Beta Tester
CoPilot II HD
PowerLab 8
jdd1 is offline        Reply With Quote
Old 12-13-2012, 11:45 AM   #3
Tim Marks
Originally Posted by jdd1 View Post
Hi Thomas,
Jack
Hi:
I can tell just by looking at that image that there's no way in he double toothpick those banana plugs will manage 60A. It'd likely to be more like 15A-20A. If you use that cable, be sure to limit the input current on the PL to no more than 20A. The reason I am so confident to say this is that those are not even solder connection style banana jacks. See the little screws on the side of the plastic housing? Last time a guy tried using something like those on the output of the PL8 (which can only achieve 40A), we posted the photos he sent us in an online forum as a "what not to do". They banana plugs got so hot, they melted the plastic housings. Not a pretty sight to see!
It's not that easy to find banana plugs that will even achieve the 40A output rating of the PL8, much less the 60A required on the input for max power.
60A is not chump change as far as current goes. It demands respect.
Tim Marks
President, FMA, Inc.
Revolectrix Partner
Tim Marks is offline        Reply With Quote
Old 12-13-2012, 12:03 PM   #4
thomascoleman
got a link for the correct cables?
Old 12-13-2012, 02:48 PM   #5
Tim Marks
Hi:
Sure. Although these are intended to be used on the output of PowerLab Battery Workstations, they would be work a lot better than the cable you showed, except that you'd have to be able to solder on your own EC5 connector. Here are the links:
http://www.usastore.revolectrix.com/...a-Plug-Cable_2
These cables are manufactured by soldering the 4mm banana plug to 12AWG silicon jacket wire, not screw terminals. The length of the actual contact area is also longer than a traditional banana plug or 4mm bullet connector and it is good quality. These will handle 40A without any trouble, but not 60A. To my knowledge there is no 4mm banana plug that will take the full 60A PL8 can draw. So, you'd still need to set your input current level accordingly.
We also have the EC5 connectors available in M/F pairs:
http://www.usastore.revolectrix.com/...EC5-Connectors
Hope this helps!
Tim Marks
Revolectrix Partner
Old 01-06-2013, 04:09 PM   #6
ferrari458italian
Hi Tim,
Would this also work between power supply and powerlab 8 with the EC5 connection?
M
ferrari458italian is offline        Reply With Quote
Old 01-06-2013, 04:15 PM   #7
ferrari458italian
Sorry, forgot the link:
http://www.progressiverc.com/ec5-charge-cable.html
M
Old 01-06-2013, 05:57 PM   #8
spackermen
Yes those will work for the input of the charger. But as Tim mentioned, the banana plugs will be the bottleneck. Not reccomended for the full 60A the charger is capable of pulling.
Respect My Authoritah!
spackermen is offline        Reply With Quote
