Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 12-13-2012, 03:31 PM   #1
Jesse
Default my back plate sensor bracket
Just wanted to share what I did to install my back plate sensor. I dont know what sensor this is i bought it used with my multigov, but it a bracket that had 50 90 printed on it and you moved the sensor by pulling one screw out.
ID:	373928   Click image for larger version
ID:	373929   Click image for larger version
ID:	373930   Click image for larger version
Jesse is offline        Reply With Quote
Old 12-13-2012, 10:34 PM   #2
bobbyra
You maybe have to grind down two of the ribs to get it closer to the back plate.
bobbyra is offline        Reply With Quote
Old 12-14-2012, 05:52 AM   #3
Jesse
No grinding fits perfectly flat against the back of the plate. Once you take the other bracket off its small enough to fit in there
Old 12-14-2012, 11:22 AM   #4
bobbyra
Less work is better good for you.
