Old 12-14-2012, 02:15 AM   #1
jamin_00
Default Does the Kosmik require the caps pre charing?
Jst trying to figure out if this will work with the Kosmik?
Emcotec switch.
http://shop.rc-electronic.com/e-vend...11&c=764&p=764
Another bit of protection thats all.
Sponsored by
Optipower
jamin_00 is online now        Reply With Quote
Old 12-14-2012, 02:32 AM   #2
Groucho_
I think Al installed one on his TDR this year... He's got a build thread, though not sure if it's included on there. Worth a look though.
Know what? Now I'm curious too. Will be digging it up...
Henseleit TDR
Trex 550E
Trex 450 Pro
Blade mSR
Groucho_ is online now        Reply With Quote
Old 12-14-2012, 12:36 PM   #3
dl7uae
Pre-charging would be nice, of course. Because it is always a big current shock for a low-ESR cap.
But if, then the ESC itself it doing the pre-charging ("anti-spark"), regardless if there is an electronic switch in front.
Tom (http://JLog.hacknet.eu)
dl7uae is offline        Reply With Quote
Old 12-15-2012, 12:33 PM   #4
ahahn
I suppose pre-charging is preferable to "pre-charring".
ahahn is offline        Reply With Quote
Old 12-15-2012, 07:26 PM   #5
Carapau
Location: God's own county. Ay oop lad, tek care lambs ont road
If it helps, I use one of these on my Helijive and it is just fantastic. It eliminates all sparking and I like the fact that I can power on the heli at arms length. I have 100s of flights with this setup and I have not seen one downside at all.
Rush 750, Vbar, 9188, BLS157HV, Kosmik 160, 4525 Ult
Fusion 50, Vbar, 9188/80s, Helijive & Quantum 4135 motor,
Mini Protos DS95s/95i, Ice Lite 50, mini v
Trex 450 Pro DS95/95i, Mini V, RJX head, Ice 50 Lite, 6s 2221-2010 DX18
Carapau is offline        Reply With Quote
Old 12-17-2012, 05:30 PM   #6
desertstalker
Pretty sure the kosmik as an anti-spark built in, it switches the caps into the circuit just after power up.
The surge will only damage connectors, the caps themselves are designed to operate in that manner.
-DX8
Old 12-18-2012, 09:59 AM   #7
jhheli
Originally Posted by desertstalker View Post
Pretty sure the kosmik has an anti-spark built in.
Yes it does
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
SAB USA, KONTRONIK, PRC, CANOMOD, PULSE ULTRA
jhheli is offline        Reply With Quote
Old 12-19-2012, 04:09 PM   #8
jamin_00
Found out it will work fine with the Kosmik.
Sponsored by
Optipower
Old 12-20-2012, 03:29 PM   #9
Wh1teAfr1can
I would be careful with it because its extra circuitry between the batteries and controller that could cause unwanted voltage ripple during flight. why would you want to use this if the Kosmik already has anti spark which is a pre charging function?
Team Kontronik
Team minicopter
Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256
Wh1teAfr1can is online now        Reply With Quote
