| Flight Stabilization Flight Stabilization |
#21 |
Wesley,
Just a question for you or anyone else.. I noticed in your video when you switch from manual mode to atti mode your swash deflect to the right and back to level when switched back to manual mode. How is this deflection affecting your flight stability? Does it cause a drift to the right? if so how are you correcting for it?
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000 Assorted Mix Fixed Wing. AMA # 972083 |
#22 |
It only does that while it is sitting on the bench not moving. While in the air, it doesn't move at all when I flip the switch from manual to Alt Hold.
Align 450 with NAZA-H, 450XL, XCell60, Align 700e, Skookum SK 720, SK-GPS, DX8. ArduPilot (APM 2). Talon 625 Hexa with NAZA-M. |
#23 |
Thank you
#24 |
Ok people, now I really want to put all in the trash.
I repeat completely the setup, so create a NEW model on the radio, with zero curves and zero trims, and I followed all the step in the order from the software. Before this, I updated the firmware. All the steps have gone PERFECTLY! Exactly like the assistant software tell, but the problem remain: Manual mode, swashplate set in wrong position. I've done another small video of all the servo monitoring from the Assistant software, where you can see that all is moving properly, swashplate and tail are perfect, except for swashplate in manual mode neutral position. Here the new vid (sorry for poor quality, ever iphone https://vimeo.com/55686133 Pass: freak Please people, I' |
#25 | |
But, now that I understand how a 3 axis gyro works, setting up the Naza-H was a lot easier. To me it looks like you might have either one servo reversed, or a setting in the swashplate mix not set correctly. Also, make sure you check your radio for servo direction as well. That can add to the confusion as well. For my DX8 all servos are set to Normal, except for Pitch, which is set to Reverse.I hope this gives you some guidance... Good luck with your setup ![]() |
#26 |
FPVflyer, could you go into the Setup tab to check a few things...
1) go to "Mode" and see if your mode switch really going to the "GPS", "A", and "M" 2) Swash. Make sure you have the correct Swash Type 3) Trim. Make sure you get 90 degree at all of your Servo trim. 4) And after that, double check again on the "Mix" screen and make sure the Cyclic Mix are following the direction on what the Setup screen shows. For the Mix screen and the Feedback, watch the Wizard carefully FIRST. Then look at your heli afterward on the second cycle. Your heli needs to follow what the Wizard shows you. I think you got one of these 2 screens wrong. Even I missed one of the four tests in the Feedback screen.
#27 |
From here: http://helifreak.com/showthread.php?t=479611
The next section is the Feedback settings. I was lost with the pictures, but now I have it. In picture 1, pitch of your blades should go positive, negtive,center. P2,Swashplate should tilt forward, backward, center P3,Swashplate roll to left, right, center, P4, Heading should pan to left, right, center by judging tail blades movement.
AMA #844172 DJI S800 WKM Z15 Nex5N iOSD Data Link Waypoint DJI F450 Naza + GPS with 5.8gHz vTx DJI Phantom with GoPro3, DJI F330 with Naza + GPS Align Trex 550 with WKH, Trex 500 with Naza H |
#28 | |
So what I can see from that is that they are using a lot of I-term on the rate. That is why it keeps moving after you hit the end of the stick, until the swash hits the end. However, it does appear to have some amount of direct proportional as well, because the swash moves quite fast at the beginning of the stick movement. It also seems like when you return the stick to center, it built-up I-term unwinds quite quickly, which is interesting. I wonder if they've done something there. I should compare that to where I'm at now. Just nice to have a benchmark. Edit: ah very cool, it's very similar to mine. The only difference is it takes my I-term a bit longer to unwind when returning to center.
-Rob Ardupilot/Arducopter Developer |
#29 |
Ok peoples, now I completely don't understand. On the time I write last post, and then I tried one more time, I simply turned on the copter and also manual mode is working perfectly! Don't know why, but better so. Tomorrow will maiden :-)
Thanks a lot for the help, the problem has been solved himselves, but all this thread help me a lot to better understand how the NAZA work! Cheers 'flyer |
#30 |
I would check that a few times with a few reboots, make sure whatever happened "sticks".
#31 |
Already reboot the system a lot of times, everytime was working right!
#32 |
That's odd. Hope it maidens ok. Good luck.
#33 |
Maiden flight 100% success!
https://vimeo.com/55854611 pass: fpvlab Thanks a lot for all the help guys! |
#34 |
Congrats! It looks great!
#35 |
It's the best I've seen so far actually - none of the tail bobbing and slight wobbling that I've seen on a few other videos.
Think that's about as good an example of perfect auto hover as you could hope to get!
Blade mCP X - Brushless, XP-7A, HP05S Gaui X2, BeastX/Scorpion 3400kv/YGE-30A/GS-093/DS95i Align AH-1 Cobra (T-Rex 500) Align T-Rex 600 EFL Pro, SK720/600MX/YGE-90HV/BL9180/BL9188 |
#36 |
That looks great! That's my benchmark.
#37 | |
#38 |
Definitely not a stock 600 Pro
Power train wise it's running a Scorpion HKIII 330kv, YGE90HV, 13T pinion straight cut pinion and 115T KDE main, Spin semi symmetrical blades on the head and tail, with a head speed around 1700rpm in that video. Would be nice to know the sort of gains it's running though - so smooth.... Hopefully FPVflyer will post his settings!
#39 |
Wow great job!!!
I can't wait to get mine in the mail. Cheers ![]() |
#40 |
Hello peoples!
I will explain the full details (already partly explained by big friend Zee Helicopter Frame: - T-REX 600 PRO 2012 (FBL) - KDE universal motor mount - 115T Helidirect main drive gear, straight thoot - 13T pinion - CNChelicopter tail control upgrade (http://www.cnchelicopter.com/servlet...600-CNC/Detail) 'cause I wil all bearings - Spinblades 600 asymmetrical blades (100% more efficient in only standard flight, with weight balance much external in the blades for higher inertia and better autorotation) - Spinblades asymmetrical tail blades RC, stabilization and power equipment: - 3x DS610 on swashplate - 1x DS650 on tail - YGE 90HV ESC (too big) - Gryphon QASAR BEC - DJI NAZA-H with GPS - Scorpion HKIII 330kv (700 size, choosed only for lower kv, fit very close to the servos) - Gens-Ace 12s 5300mah (fit precise at mm!) - EzUHF long range system with diversity receiver and 2x dipoles antennas FPV Equipment: - TBS59 camera (590TVL) - TBS CORE (for 12s monitoring and camera + vtx power supply) - FLIR TAU2 640 (thermal camera for search and rescue) - NGHOBBIES video switcher (more in testing, for FLIR/standard picture switch) - 2s 2500mah lipo for video (will go down to 1500mah soon) - MCtronic device for RSSI digital to analog converter - 2.4ghz video transmitter with SPW antenna from Circular Wireless Interesting information, yesterday I've done the first LR flight, 22mins in the air, 2km away, and very quiet flight. In hovering it drain 10,5A, keep moving on flight level around 9,5A, descending 3,5A. Must add more 1amps for all the RC system + FLIR camera, and finally the average flight time will be around 18-20mins That's all I think, if someone is really interested I can open a thread presenting it, and continue it during his carreer in SAR |
