#61 |
#62 |
Try changing it to 8 to 10mm and reset the end points.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. The art in flying RC Helicopters lies in learning how to throw it at the ground and miss. Tarot 450 Pro - Chaos 500 |
#63 |
The gyro should lay flat.
#64 |
Alex. Review the instructions on page 14 of your manual. Top right corner shows which hole to put the ball in on the servo horn and make sure your using the correct servo horn.
#65 | |
Goon a do that tonight.
It will be flat but twisted to 45° of what it is now. . Apparently its the right thing to do Quote:
Is it something stupid we are missing on the hi tech a aurora 9 programming ? Thanks for the replies |
#66 |
Not sure how the gains are set up in the Tx of yours...but in alot of Tx.. the gains are set from 0 to 100, 50% being neutral. I know Futabas are set up 100 to 0 to 100 with 0 as neutral.
With 0 to 100.. anything over 50% is HH, anything below is rate mode. You want to start at about 65%, raising and lowering the gain alittle at a time to try to stop the wag. 19mm sounds like an awful lot for the tail link on the servo arm. Mine is 10mm on all my 500's. RE the gyro....I believe it doesnt matter which way it faces as long as its not on its edge???? ![]() OH.. I should explain....my gyro gain is in the AUX2 slot on the Rx, which corrosponds with the switch on my Tx for AUX/GYRO....in the Tx, I have the switch when its at 0 set to HH ( 68%) mode.. and when the switch is set to 1, its set to 40% ( rate mode ) I use rate mode to center the tail blades before spooling up sometimes. I fly in rate once in awhile.. just to have some different practice...
Trex700N2E Trex500ESPTT(PRO head and Tail ) Trex500ESP (Belted) HC500SE All flying Spartan, CC100A, CC20APro, Hitec 5245MG, Futaba 9257, Walkera Devo 8S, KBDD, i2! |
#67 |
Yes the ball should be close to 10mm. Where did you read 19? If your ball is out 19 that is your problem right there
#68 |
Yeah, agreed. Try moving it.
#69 |
I'm such an idiot !
I just measured it and it is at 10mm don't know what I was thinking with 19 . ( I must lay off the beer) so that's not the problem .So new gyro pads and twist to 45° is the next thing to try , but it seem that no one has heard of this. |
#70 |
I will have my beer next weekend Alex! Glad we sorted the tail issues. I think once heli has had a few more flights it will settle in and the trim issues can be sorted, I think the ball links are a little tight still on the head but that's nomal on any new heli. I forgot to look at the gain on the gyro as its got a bit of a wag in ff flight. Hell of a lot more exciting than planks eh!
Sent from my HTC Desire HD A9191 using Tapatalk 2
IF YOU DON'T MIND COULD I CRASH YOURS INSTEAD AS I JUST GOT MINE THE WAY I LIKE IT. THANKS |
#71 | |
![]() Just to say to guys having tail issues with the align gyro on the 500 try twisting the gyro to 45° still flat but twist it. It may not work for you all but mine has gone from jelly to rock just with this mod If Ian would like to pitch in with why it worked as I'm still a noob I had the best pilot to help with mine , top guy, still has plenty of time to help a noob out . I love this hobby ![]() |
#72 |
Thats a first for me!!!!
Glad you got it worked out. I'd like to know more about this, as I've never heard of turning any gyro 45° to sop a tail wag. Congrats!!!
#73 | |
Thanks for sharing!
Team HeliDirect Skookum Support Flying Align, controlled by Skookum, and powered by Pulse |
#74 | ||
. Its not the first time its been done at the club. Quote:
I did not change anything else . |
#75 |
Alex, you are a bit in front of me. I went mad over Christmas. I bought a Beast X for my Gaui 255 to X2 conversion and suddenly thought 'what am I doing?' and bought the DFC head and swash for the ESP and slapped it all on that instead! I also put a Pro tail case, grips and upgraded pitch slider on it. I took it out on Sunday for the maiden but luckily realised that I had forgotten to put the retaining screws on the servo arms
Spooled it up on the ground and it sounds sweet. Next Sunday is the big day if the weather keeps off. Congrats on getting yours into the air, that is brilliant. PS Fast Lads have a tenner off the orange carry bag if you need one.Last edited by senoj; 01-14-2013 at 04:23 PM.. Reason: Speller |
#76 |
Mine has somewhere to live , I got a case for xmas
