Old 01-06-2013, 01:42 PM   #61
one life fly it
Originally Posted by grawyl View Post
What is your gyro setting in your tx? Do you have the servo ball at 10mm out on the servo arm?
Its set as instructions is that wrong 19 mm
Originally Posted by mhills51 View Post
What kind/brand of gyro?
The one that came in combo align gp780
one life fly it is offline        Reply With Quote
Old 01-06-2013, 01:50 PM   #62
grawyl
Try changing it to 8 to 10mm and reset the end points.
The art in flying RC Helicopters lies in learning how to throw it at the ground and miss.
Tarot 450 Pro - Chaos 500
grawyl is offline        Reply With Quote
Old 01-06-2013, 02:02 PM   #63
mhills51
The gyro should lay flat.
mhills51 is online now        Reply With Quote
Old 01-06-2013, 02:58 PM   #64
grawyl
Alex. Review the instructions on page 14 of your manual. Top right corner shows which hole to put the ball in on the servo horn and make sure your using the correct servo horn.
Old 01-07-2013, 11:43 AM   #65
one life fly it
Goon a do that tonight.
It will be flat but twisted to 45° of what it is now. . Apparently its the right thing to do
I definitely am using the right one, just checked the size etc , gonna take a spare up the field with the ball at 10 mm .
Is it something stupid we are missing on the hi tech a aurora 9 programming ?
Thanks for the replies
Old 01-07-2013, 07:51 PM   #66
Blayd
Not sure how the gains are set up in the Tx of yours...but in alot of Tx.. the gains are set from 0 to 100, 50% being neutral. I know Futabas are set up 100 to 0 to 100 with 0 as neutral.
With 0 to 100.. anything over 50% is HH, anything below is rate mode.
You want to start at about 65%, raising and lowering the gain alittle at a time to try to stop the wag.
19mm sounds like an awful lot for the tail link on the servo arm. Mine is 10mm on all my 500's.
RE the gyro....I believe it doesnt matter which way it faces as long as its not on its edge????
OH.. I should explain....my gyro gain is in the AUX2 slot on the Rx, which corrosponds with the switch on my Tx for AUX/GYRO....in the Tx, I have the switch when its at 0 set to HH ( 68%) mode.. and when the switch is set to 1, its set to 40% ( rate mode ) I use rate mode to center the tail blades before spooling up sometimes. I fly in rate once in awhile.. just to have some different practice...
Trex700N2E
Trex500ESP (Belted)
HC500SE All flying Spartan, CC100A, CC20APro, Hitec 5245MG, Futaba 9257, Walkera Devo 8S, KBDD, i2!
Blayd is offline        Reply With Quote
Old 01-07-2013, 08:00 PM   #67
mhills51
Yes the ball should be close to 10mm. Where did you read 19? If your ball is out 19 that is your problem right there
Old 01-07-2013, 08:04 PM   #68
Blayd
Yeah, agreed. Try moving it.
Trex700N2E
Trex500ESP (Belted)
Old 01-08-2013, 11:43 AM   #69
one life fly it
I'm such an idiot ! I just measured it and it is at 10mm don't know what I was thinking with 19 . ( I must lay off the beer) so that's not the problem .
So new gyro pads and twist to 45° is the next thing to try , but it seem that no one has heard of this.
Old 01-13-2013, 10:48 AM   #70
ian m
Default Re: hi from a new 500 owner
I will have my beer next weekend Alex! Glad we sorted the tail issues. I think once heli has had a few more flights it will settle in and the trim issues can be sorted, I think the ball links are a little tight still on the head but that's nomal on any new heli. I forgot to look at the gain on the gyro as its got a bit of a wag in ff flight. Hell of a lot more exciting than planks eh!
Sent from my HTC Desire HD A9191 using Tapatalk 2
IF YOU DON'T MIND COULD I CRASH YOURS INSTEAD AS I JUST GOT MINE THE WAY I LIKE IT. THANKS
ian m is offline        Reply With Quote
Old 01-13-2013, 11:12 AM   #71
one life fly it
Can't thank you enough for your Time and patience with my heli
Just to say to guys having tail issues with the align gyro on the 500 try twisting the gyro to 45° still flat but twist it. It may not work for you all but mine has gone from jelly to rock just with this mod
If Ian would like to pitch in with why it worked as I'm still a noob
I had the best pilot to help with mine , top guy, still has plenty of time to help a noob out .
I love this hobby
Old 01-13-2013, 02:57 PM   #72
Blayd
Thats a first for me!!!!
Glad you got it worked out. I'd like to know more about this, as I've never heard of turning any gyro 45° to sop a tail wag.
Congrats!!!
Trex700N2E
Trex500ESP (Belted)
Old 01-13-2013, 08:35 PM   #73
tomd27858
Congrats!!!
I think quite a few of us are going to have to stick that in our bag of tricks. I had never heard of it before either.
Thanks for sharing!
Team HeliDirect
Skookum Support
Flying Align, controlled by Skookum, and powered by Pulse
tomd27858 is online now        Reply With Quote
Old 01-14-2013, 11:08 AM   #74
one life fly it
Congrats!!!
I really am still not sure why it works its something to do with the position of the sensors
. Its not the first time its been done at the club.
Thanks for sharing!
I hope it works for other peeps too. Only time will tell . The transformation was amazing ! Only wish i'd taken some spare pads last week and we could had done it there and then.
I did not change anything else .
Old 01-14-2013, 04:20 PM   #75
senoj
Alex, you are a bit in front of me. I went mad over Christmas. I bought a Beast X for my Gaui 255 to X2 conversion and suddenly thought 'what am I doing?' and bought the DFC head and swash for the ESP and slapped it all on that instead! I also put a Pro tail case, grips and upgraded pitch slider on it. I took it out on Sunday for the maiden but luckily realised that I had forgotten to put the retaining screws on the servo arms Spooled it up on the ground and it sounds sweet. Next Sunday is the big day if the weather keeps off. Congrats on getting yours into the air, that is brilliant. PS Fast Lads have a tenner off the orange carry bag if you need one.
senoj is offline        Reply With Quote
Old 01-15-2013, 12:45 AM   #76
one life fly it
Mine has somewhere to live , I got a case for xmas
