Old 12-14-2012, 06:01 PM   #1
bono1
Default RL 100
Anyone running the rl 100? Thinking about trying something different.
Thanks,
Sam
blow smoke
bono1 is offline        Reply With Quote
Old 12-15-2012, 10:54 PM   #2
Grok
No, but if you get it, please tells us how it works out.
Grok is online now        Reply With Quote
Old 12-16-2012, 02:18 AM   #3
NitroAl
Yep
http://www.archeli.com.au/forums/sho...=149934&page=2
Also check out the vid and comments on this page http://www.archeli.com.au/forums/sho...156564&page=11
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 01-06-2013, 09:16 AM   #4
mainblades50
What is a ball park setting on the needle valves? high turns out, low clock position?
Thanks Barry
Team Chaos-RCAerodyne AMA# 132496
Chaos 700N FBL BW Gyro, Thunder Tiger 1.00RL
Chaos 600N FBL IKon Gyro
mainblades50 is offline        Reply With Quote
Old 01-07-2013, 02:19 AM   #5
NitroAl
Mine will be very different to yours, today was a cool day at just 29c and only about 20m above sea level!
I run rotor rage 30% with high needle at around 1 3/4 turns out and low needle 1/16 out from flush!
Ely.Q Vision 90
Ely.Q Vision 50
Old 01-08-2013, 11:59 PM   #6
Phil777
A few guys are running them in new zealand with good results so far.
i believe they are only using 15%
I might give one a try instead of a os105 for my nitro conversion
RCRage
Raptor G4, Rail Blades, Byron Fuels
Phil777 is online now        Reply With Quote
