| Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters |
Hi Guys,
Does anyone know how to use the governor mode on the EB ESC40A ESC? I have switched it on and set a linear throttle curve. This seems to work fine until I hit throttle hold on an auto and then bail out. When the throttle kicks in, the rpm is significantly lower? Thanks for any help Argy
Argy ---------------------------------------------------------------------------- Copterx 450 SE V2, Trex 250SE, MCPx, MSR, Nine Eagles Solo. |
i have my stock esc gov on and all my idle up modes on a flat curve. when i switch out off throttle hold, i don't notice my headspeed lower than it was before. since you have your throttle on linear curve, could it be your throttle input is lower when you switch out of throttle hold? i have heard others saying there's an issue with the stock esc in gov mode but i really like it and have yet to experience any problems with mine
thanks,
I did subsequently notice that the pitch curve in hold was not linear, but I don't know if that had anything to do with it. I'll look over it again Thanks for the feedback Regards Argy
you can also try doing that with a fresh lipo and see if the power would decrease when you come out of throttle hold
