Old 12-16-2012, 11:00 AM   #1
exhogflyer
Default Foam for Skids?
Where do most folks get the bright color foam tubes that I've seen on the landing skids? I know it's to help dampen vibration but the bright colors help orientation in the air. I've looked at normal pool "noodles" but they seem to be WAY too fat. Thanks!
CX3,130X,Trex 450SE,450 PRO
Bergen Intrepid Gas & Turbine
HK600GT,HK500CMT,Goblin 770
Trex 700N,Trex 800E,Trex 800Gasser
exhogflyer is offline        Reply With Quote
Old 12-16-2012, 11:06 AM   #2
nightflyr
"Pool Noodles" are a good choice..
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000
Assorted
Mix Fixed Wing.
AMA # 972083
nightflyr is online now        Reply With Quote
Old 12-16-2012, 11:08 AM   #3
flim63
Most local shops don't carry them in the winter so you might have to go online. In spring, you should be able to find them everywhere, Target, Walmart and pool supply stores. I got some small ones (2.5" dia.) at Target.
flim63 is offline        Reply With Quote
Old 12-16-2012, 11:19 AM   #4
exhogflyer
That's what I'm looking for! But the only ones I find are about 6" in diameter!
Old 12-16-2012, 11:31 AM   #5
Goldenhour
Some of those dollar stores and in the spring others have various sizes. Probably find em online for next to nothing.
Pipe insulation works for the stealthy low profile look.
Goldenhour is offline        Reply With Quote
