Old 12-16-2012, 01:52 PM   #1
fastblackbird1
Default Microbeastx (what I doing wrong)
Hi, I am new with FBL and I just try to set up microbeastx in trex 500 with the manual, everything was fine until the section ( I ) in the manual, I can't make the servos at the swash plate move at right direction, I already tried reverse the servos at the transmitter and tried the combinations what the manual say and check all the wires and also change the servos and receiver wires and the mixer functions in the transmitter (swash mixer), The swash its level already just the servos move in different direction and also the swash its set a 120.
I already build another 2 helis but those was FB and this one is my first one.
Thank you so much
P.S. Today is my second time that I tried and I don't know what I doing wrong.
fastblackbird1 is offline        Reply With Quote
Old 12-16-2012, 02:43 PM   #2
helidom
Make sure swash is 1 servo normal in tx, then get pitch moving all three servos the same direction, go through each combination systematically until its correct.
helidom is offline        Reply With Quote
Old 12-16-2012, 03:02 PM   #3
fastblackbird1
ok I will try that, to see if fix it, Thank you
Old 12-16-2012, 03:18 PM   #4
fastblackbird1
Thank you HELIDOM Now its working
