Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 12-16-2012, 02:24 PM   #1
Alignnitro
Default NX4 Cooling Fan
Hello to all,
I'm not sure if this has been brought to the table or not but I wanted to share some info I looked into a little. I know there has been a lot of issues with the magnets coming off the Gaui Stock and I just so happen to have an Align 600 Nitro fan sitting around that I picked up and found some interesting info. Just thought I would share ... To me this is a better fix than " using a light coat of epoxy to cover the magnet "
The Pictures below are pictures of an Align 600 Nitro fan and a Gaui Nx4 Fan. The Align fan has a matte finish to the plastic where the Gaui fan has a shiny finish to it. The pictures show that the fan is the exact same size all the way around with the exception of the magnet hole of which I think maybe this could be the reason they are flying out. The Align fan has a little bit deeper of a hole ... It also feels like the ALIGN fan is a little bit more solid.. IMOP Ive never had an issue with my Align fans so it looks like Ill be going this route..
ID:	374639   Click image for larger version
ID:	374640   Click image for larger version
ID:	374641   Click image for larger version
ID:	374642   Click image for larger version
ID:	374644   Click image for larger version
Alignnitro is offline        Reply With Quote
Old 12-16-2012, 02:32 PM   #2
Si_B
If you have it out, you might as well upgrade to a metal fan. Always found these to run smoother than any plastic fans.
Bought a metal fan for mine, just need to find the time to strip it out.
Si_B is offline        Reply With Quote
Old 12-16-2012, 04:33 PM   #3
u8at711
with over 30 flights on my stock fan, I never had a problem with it, took it out today, and installed a lynx alum fan,
inspected the stock fan, there was nothing wrong with it. in my parts box now.
YTD Nitro smoked = 14 Gal
YTD Flights 0303
Gaui NX4 106 flights, Fury 55 022 flights
Smokem' if you got em'
u8at711 is offline        Reply With Quote
Old 12-16-2012, 06:29 PM   #4
Superx
I had a problem with the stock fan and went to the align and have two gallons on it and no problems at all.
Superx is offline        Reply With Quote
Old 12-16-2012, 08:13 PM   #5
timmytron
Which Lynx alu fan are you installing? The Trex 600 one?
Team Old Mate - He's a good bloke
timmytron is offline        Reply With Quote
Old 12-17-2012, 06:48 AM   #6
u8at711
yes, it's made for the 600, but don't have the word align on it,
YTD Flights 0303
Old 12-28-2012, 12:44 PM   #7
RonFly
Default magnet question
My NX4 is in the mail. I assume I can fly without a governor? But I would like to install the magnets just in case. Where are you finding spare magnets when you lose them? Thanks.
RonFly is offline        Reply With Quote
Old 01-03-2013, 10:13 AM   #8
jczankl
New Metal Fan coming soon.
JC Zankl
Team Empire/GAUI,Team Savox Servos,Team Hyperion,
Team PowerMaster Fuels,Team Castle Creations,
Dillon Sunglasses,Vel-Tye,Hardcorepimpgear.com
jczankl is offline        Reply With Quote
Old 01-03-2013, 12:04 PM   #9
Blade3d
Which Align metal fan are you guys using ?
Blade3d is offline        Reply With Quote
Old 01-03-2013, 12:15 PM   #10
jczankl
Default GAUI Metal Fan
New GAUI Metal Fan Part Number G-313105
JC Zankl
Old 01-03-2013, 01:25 PM   #11
Si_B
This is the one I used here
Comes with the magnets as well, so you can leave your plastic as a spare.
Cheers,
Simon
Old 01-04-2013, 12:55 AM   #12
Blade3d
Thanks for the reply guys
Old 01-09-2013, 04:28 PM   #13
audio131
Default align fan
seems to fit fine and it comes with magnets .
audio131 is offline        Reply With Quote
