Old 12-16-2012, 05:14 PM   #1
Charliedontsurf
Default Can Protos Be Set Up Mild?
Hey Gang,
Looking for an idea...Gonna fly 500 sizes as my smallest Heli, already have a Trex 500 flybarred, but want something more nicely engineered, but can these guys be set up tame for F3C type manuevers, or are they just wild 3D mini-monsters!
Gonna maybe do one FBL, to complement the Trex500 that I have to have 2 of the same size birds to continue my training on...
Thanks for any ideas...
Franz in NJ
Do You want to fight, or Surf?
Goblin 500 DX8 T Rex 500 Trex450
Blade mCPX mCPXBL mQX
Charliedontsurf is offline        Reply With Quote
Old 12-16-2012, 05:59 PM   #2
crickr1
Hey Franz,
that's the nice thing about Protos, mild or wild, you decide. Wide range of pinions to choose from, You can even stretch it to run 473s and dial it down some more for a much more "Floaty" feel. With it's light weight you should be able to get some really good flight times from it too.
Keep it in the air!
Lovin MSH!
hybrid Gaz/otos fbl,stretched 6s MiniP Stretched PROTOS 500 ,EC135 Era/Protos500,Compass 6HV, Gaui NX4 all MSH-Brain/Futaba8FG Compass 3D+ CGY750
crickr1 is offline        Reply With Quote
Old 12-16-2012, 06:00 PM   #3
shadco
Originally Posted by Charliedontsurf View Post
Hey Gang,
Franz in NJ
Simply yes.
There is a little pucker factor out of the gate but I've basically learned to fly with mine, that and a Fusion 50.
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar
SAB G500 Savox 4050 KST/MKS HV YGE HC3SX
Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8
shadco is offline        Reply With Quote
Old 12-17-2012, 08:45 PM   #4
sly
Can sombody please suggest some settigs for MILD performance?
sly is offline        Reply With Quote
Old 12-17-2012, 09:08 PM   #5
rossk
you are going to need to supply some more info if you want an accurate answer:
FB/FBL - controller?
ESC?
Motor?
Stretch?
Blades?
Radio?
In General:
Head speed: low - 2000rpm
Expo: lots - 30%
DR: low - 70%
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp TT E820 - Kosmik 200, Scorp 5035
MA Whiplash - Kosmik 200, Pyro 700 TREX 700E - DFC Pro HV, Kosmik 200, 850MX
Protos 500 Stretch + Protos 500 + Protos Mini Stretch
MSH Brain Spektrum DX8
rossk is offline        Reply With Quote
Old 12-18-2012, 08:13 PM   #6
sly
Thanks,
FBL - BeastX ver 3.0.8
ESC - Castle creations ICE lite 75
Motor - Stock Lipotech with 12T pinnion
Stretch- No
Blades - SAB
Radio - Futaba T7C
Just finished installation of BeastX. Pitch and throttle curves not yet set.
Old 12-18-2012, 09:59 PM   #7
flint723
I can offer some insight. First of all I would get a castle link so you can use the governor. You can get 2100 governed with 12t pinion which should be pretty good for what you say you want. As far as travels, I would set up the beastx with collective at +/-11° and cyclics at +/-10° at 100 percent travel in the tx. That way you can set your dual rates for like 80% on cyclic to start out with and see how it feels. With maybe 20% expo. I would use the full pitch curve though, you will probably want it at this low head speed. I used to fly my non stretch at 1950 rpm, it was pretty marginal on power though, and on tail authority. It was great for just flying around and getting good flight times though. The low head speed alone makes it less twitchy.
Fusion 50, Quantum 4125-560kv, Ice2 HV 80a, w/ G31
12s Protos 500 stretched, Kora 25-16 420kv, Ice2 HV 40a, G31
Tarot 450 dfc 6s stretched, Tarot 450mx 1700kv, Ice 50a, G31
All on Devo 8s w/ Deviation
flint723 is offline        Reply With Quote
Old 12-19-2012, 11:45 AM   #8
kavic5150
Post
I run a 14t pinion and was using the stock scorpion 3026-880kv. With a shallow v curve around 70% I was getting 7 minute flight times on brand new 6s 2650mah packs.
My headspeed was around 2100rpm or so.
If you dont mind a bit more weight, use 6s 2800mah packs. The one I had was shorter than my other 2650 packs and I had to slide it away from the main shaft a bit for proper CG.
Still floaty with that setup, but much more tame.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is offline        Reply With Quote
Old 12-20-2012, 08:16 PM   #9
sly
Thanks flint and kavic.
I have the governer set up using the castle link. Its almost ready for the test flight.
Regards,
Old 12-20-2012, 08:24 PM   #10
flint723
Let us know how it goes. Good luck
