Old 12-16-2012, 06:56 PM   #1
joecass2
Default what nitro starter???????????????
i left my align starter at the field and when i went back for it. it was no longer there.
what starter would you guys reccommed?
joecass2 is offline        Reply With Quote
Old 12-16-2012, 07:00 PM   #2
nynextel88
Sullivan dynatron. Can use up to a 6S pack and will start just about anything. Turns over my regulated 91 size engines with ease, even on a cold start. Best 90 bucks I've ever spent!
nynextel88 is offline        Reply With Quote
Old 12-16-2012, 07:07 PM   #3
McKrackin
I might give the Sullivan a try.
My Align starter has worked great for years but my new OS105 is killing my 4S lipo pretty quick.
McKrackin is offline        Reply With Quote
Old 12-16-2012, 07:23 PM   #4
airpup86C
When my Align self destructed I went with a Sulivan Dynatron as well. I found that with a 6S pack, if the engine was hydro locked, it would melt the switch contacts together, No damage to the engine, ( it did cause the one way on the Knight to slip a couple times, which sounds really bad!) but it was a bit awkward after pulling the starter out to get it to stop spinning!
So I went with a 5S pack and no more trouble. Now if I have a hydro locked engine, no more drama. The starter just stalls, then I clear the engine, then I fire it up.
Al
T-Rex 500GF, Compass Knight 3D,Raptor E700, Rave 450
Newest member of the fleet: Synergy N7
Futaba 14SG
airpup86C is offline        Reply With Quote
Old 12-16-2012, 10:20 PM   #5
joecass2
anyone using the Hobbico TorqMaster 180 Heavy Duty 12 Volt?
also how to you get a air plan starter to start a heli is there a adaptor i need?
Old 12-16-2012, 11:10 PM   #6
airpup86C
Originally Posted by joecass2 View Post
...also how to you get a air plan starter to start a heli is there a adaptor i need?
Yes, I had to adapt the starter for heli use. Since my current ships have built in one way bearings in their starter shafts, I went the cheap route and just bought a basic JR clamp-on starter wand. The trickiest part to installing it was actually getting the stock starter cup off. I used an air impact wrench to get the nut loose, but I had to pull the starter apart to be able to unscrew the cup itself. Here's a pick of mine with it's crude but effective battery mount.
And here's a pic of the unit dis-assembled, after removal of the cup.
Hope this helps
Al
Futaba 14SG
Old 12-16-2012, 11:13 PM   #7
755 robert
I have used one of these, it worked fine,not as nice as the solid fit but it works on my 700n..
http://www.advantagehobby.com/98163/...2051/?pcat=528
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even.
.Who is John Galt?
755 robert is offline        Reply With Quote
Old 12-16-2012, 11:15 PM   #8
Ah Clem
Sullivan Dynatron here too.
I used a Thunder Tiger starter for a while, with success on .50 sized machines.
When I started flying .90s, the Dynatron on 24 volts was needed.
Great starter!
Old 12-16-2012, 11:25 PM   #9
flyinghigh450
The TorqueMaster 180 HD will be MORE than enough..I use the TorqueMaster 90 with a 1600mAh 4S lipo..Started everything from a OS 37 to YS 120SR/OS 105HZ with it and it spins the big engines over SUPER easy.The lipo will last days without needing charged...
Team Align
flyinghigh450 is offline        Reply With Quote
Old 12-17-2012, 12:03 AM   #10
chosen69
+1 on the Sullivan Dynatron.
If you wanna go all out get the Makita battery adapter for it for a really clean look.
http://www.afineredgemfg.com/index.htm
Trex 600EFLpro
Trex 600NSP DFC
Trex 700E DFC
Goblin 700
chosen69 is offline        Reply With Quote
Old 12-18-2012, 10:41 AM   #11
ChadL
That's what I use on my Dynatron starter. I already had makita batteries and charger so it was economical for me to use the adapter by Finer Edge. The setup works very, very well. I'm very pleased.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar
Voodoo 400 SK540
ChadL is offline        Reply With Quote
