| Engines and Mufflers Having problems or need advice on Engines or Mufflers? |
i left my align starter at the field and when i went back for it. it was no longer there.
what starter would you guys reccommed? |
Sullivan dynatron. Can use up to a 6S pack and will start just about anything. Turns over my regulated 91 size engines with ease, even on a cold start. Best 90 bucks I've ever spent!
Team HeliProz Team HAIYIN batteries Team Lynx RCGalore |
I might give the Sullivan a try.
My Align starter has worked great for years but my new OS105 is killing my 4S lipo pretty quick. |
When my Align self destructed I went with a Sulivan Dynatron as well. I found that with a 6S pack, if the engine was hydro locked, it would melt the switch contacts together, No damage to the engine, ( it did cause the one way on the Knight to slip a couple times, which sounds really bad!) but it was a bit awkward after pulling the starter out to get it to stop spinning!
So I went with a 5S pack and no more trouble. Now if I have a hydro locked engine, no more drama. The starter just stalls, then I clear the engine, then I fire it up. Al
T-Rex 500 GF, S9650 MGs, Futaba CGY 750 FBL, DFC Head, DS8910A+ tail, Scorpion 1600 Compass Knight 3D, VBar, BLS253x3, S9254 tail, OS 50 Hyper, Multigov, Perfect Reg. T-Rex 700N, OS91HZ, BLS253x3, Multigov, BLS251+Quark, SG X2 Last edited by airpup86C; 12-16-2012 at 10:29 PM.. |
anyone using the Hobbico TorqMaster 180 Heavy Duty 12 Volt?
also how to you get a air plan starter to start a heli is there a adaptor i need? |
#6 | |
And here's a pic of the unit dis-assembled, after removal of the cup. Hope this helps Al
T-Rex 500 GF, S9650 MGs, Futaba CGY 750 FBL, DFC Head, DS8910A+ tail, Scorpion 1600 Compass Knight 3D, VBar, BLS253x3, S9254 tail, OS 50 Hyper, Multigov, Perfect Reg. T-Rex 700N, OS91HZ, BLS253x3, Multigov, BLS251+Quark, SG X2 |
#7 | |
http://www.advantagehobby.com/98163/...2051/?pcat=528
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class( To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ).Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even. .Who is John Galt? |
#8 |
Sullivan Dynatron here too.
I used a Thunder Tiger starter for a while, with success on .50 sized machines. When I started flying .90s, the Dynatron on 24 volts was needed. Great starter!
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
#9 | |
Team Align |
#10 |
+1 on the Sullivan Dynatron.
If you wanna go all out get the Makita battery adapter for it for a really clean look. http://www.afineredgemfg.com/index.htm
Trex 600EFLpro
Trex 600NSP DFC Goblin 700 |
#11 | |
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar Kasama Srimok ECO CGY 750 Mini Prôtos CGY 750 |
