Old 12-16-2012, 07:43 PM   #1
dmc45
Default X-cell 30???
Received what I believe is an Xcell 30. I'd like ot get it running but have a lot to learn about this heli. Everything looks good but the throttle does not move. Maybe froze up but it does not look like it moves. It has a servo tied to it so it must move right? I have experience but all electric...like the blade SR. Also, how do I match up RX and TX? Should I purchase a new set.
Any information on this heli would be greatly appreciated.
THanks,
Doug
dmc45 is offline        Reply With Quote
Old 12-16-2012, 11:15 PM   #2
Rudy
disconnect the throttle linkage from the carb. Will the carb work with the linkage disconnected.
if not you need to remove the engine and then the carb from the engine. Soak the carb in some alcohol that should free it up.
Rudy - Currently in ??? It depends on the day of the week where I am
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote
Old 12-17-2012, 04:13 PM   #3
dmc45
Default Thanks
Thank you! It does not move so i will take it apart and soak it.
Old 12-18-2012, 04:40 AM   #4
flyin dan
Rons Heli Pros south is your best bet for Min-Air parts. Tear it down and check all bearings, the X-cell 30 is still a good machine when setup properly.
flyin dan is offline        Reply With Quote
