Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 12-17-2012, 12:45 AM   #1
ahnjason
Default How do you connect battery
Hi guys,
Which way do you prefer?
I prefer the setup on the left in illustration because I like to power up and initialize Vbar first by connecting 6s#1 then connect 6s#2 to initialize ESC on all my 12s Logos and Synergy.
Or should I choose setup on the right in illustration? Make 12s first by connect 6s#1 and 6s#2 then connect to the YGE and BEC?
Thank you for looking.
ahnjason is offline        Reply With Quote
Old 12-17-2012, 01:04 AM   #2
LogoFreak
I would go with the illustration on the right, 12s pack first then to esc/bec
DX18
nCPX
Skype: LogoFreak
LogoFreak is offline        Reply With Quote
Old 12-17-2012, 02:42 AM   #3
dart
If you do option one, you will kill your electronics.
Your numbering is the wrong way around. Always start from the black (-) side on your esc.
dart is offline        Reply With Quote
Old 12-17-2012, 02:52 AM   #4
faxxe
Dart has right. Like on picture 1, you will kill you r electronic.
Please read in that thread the post from electricsheep:
http://www.helifreak.com/showthread.php?t=428497
If you connect your BEC to just one Pack, connect it to that pack, where the black (minus) cable goes
to your ESC (in your graphic called "6V #2").
-Heimo
Logo 800 XX / Pyro800 comp / Kosmik200+ / S9352hv_BLS256 / Vstabi 6.0 / Edge 813
Raptor e720 / 4530 / Kosmik160+ / JR8921&256 / Vstabi6.0 / DH 711
Mikado VBC
faxxe is offline        Reply With Quote
Old 12-17-2012, 02:56 AM   #5
DannyvG
be very glad that you didnt connect the second lipo yet because it will blow up your bec and perhaps all your electronics.
in the image you have the bec on the 6-12S side while it should be on the 0-6S side. The way you have it in the image you will have a 25V difference in ground.
If you switch the bec to the other side, so bec ground is esc ground then you should be good to go.
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote
Old 12-17-2012, 03:12 AM   #6
ahnjason
Thank you for the correction...
Edited now.
My drawing on the left is wrong.
I meant this...
Old 12-17-2012, 04:38 PM   #7
prototype3a
I like 'left style' because...
Can power electronics with out powering ESC
Can use less expensive 10s max BECs
I also install an EC2 between the BEC and the pack connector so I can easily swap out the BEC if needed.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL
prototype3a is offline        Reply With Quote
Old 12-17-2012, 06:07 PM   #8
Mentalic
I do the option to the right, plus use a western robotics battery buffer board, it takes two power sources, outputs the higher voltage. Also use a small 450mah 2s lipo as one of the power sources to boot system and also to tweak V-bar without powering up ESC/BEC.
This thing is just a diode OR circuit but the package is very neat, also has led's on each input and the output.
http://www.readyheli.com/WRL-BBFR-We...r_p_40635.html
Wayne Armstrong
Team Mikado USA
Logo 480 / Logo 600sx / Logo Uvular / Logo 700 / Vbar Control
Mentalic is offline        Reply With Quote
Old 12-19-2012, 06:43 AM   #9
Laughingstill
The left is a 6s setup and the right is a 12s setup. Either one will work it just depends on what BEC you choose. When someone has a Jive, the BEC inside the ESC comes on when the ESC is connected as well. There is nothing wrong doing it either way as the VBAR does not send signal to the ESC until it is initialized.........Ron
Laughingstill is offline        Reply With Quote
Old 12-19-2012, 06:57 AM   #10
TommyBear
HF MR Support
If you use a castle Bec, go with the 6S option as you will have higher current output from the BEC. I use the updated Left 6S connection on my L700 equipped with a CC Pro BEC.
Lynh
TommyBear is offline        Reply With Quote
Old 12-19-2012, 09:15 AM   #11
Laughingstill
I personally don't like CC BECs and with HV servos, why not just go 2s lipo direct??? That way if the main connection comes loose or fails, you still have control of the servos.
