Old 12-17-2012, 03:25 AM   #1
TSully
Default 6s motor
I recently picked up a stretched mini p airframe as my first "bigger" heli. Was really looking at the warp but decided the mini p was a better decision. Im looking to do a 6s setup but having trouble locating a motor. any help would be appreciated
TSully is offline        Reply With Quote
Old 12-17-2012, 11:58 AM   #2
NC_2_VA
I brought one from Helidirect about two weeks ago. Beware your choices for 1300-1350 mah lipos are limited. The options for a 4s setup are better.
Grand RC
Citizen 242
NC_2_VA is online now        Reply With Quote
Old 12-17-2012, 12:45 PM   #3
mahbouni
You won't regret getting a MiniP. Just make sure you align the frame sides correctly so that the bearing blocks are not skewed. This will make sure you have a level surface to mount your gyro/FBL unit on and it will fly more accurately. I used an empty servo case on the opposite side of the elevator servo to align the bearing blocks perfectly.
For a 6s setup the only current choice is the MSH branded Scorpion 2221-1300KV. The Compass Warp motor has a 4mm shaft so it won't work in the MiniP and I'm not aware of anything else with low enough KV. There is talk about Scorpion producing a 2520 motor for the Compass Warp. It would just need a shaft suitable for the MiniP and I'm sure they will sell it to us even if MSH don't commission it. I have told Perry at Scorpion that I would like to test such a motor when the prototype is ready.
Oxy3+ | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | JR Forza 700 | VControl
mahbouni is online now        Reply With Quote
Old 12-22-2012, 11:14 PM   #4
TSully
Still can't find 6s motor in stock anywhere......anybody have one they wanna sell or know where i can get one?
Old 12-23-2012, 12:22 AM   #5
dl5973
I want one too
dl5973 is offline        Reply With Quote
Old 12-23-2012, 12:23 AM   #6
dl5973
Umma you said Mini Protos and Align in the same paragraph
Old 12-23-2012, 04:48 AM   #7
mahbouni
Just search Google for MSH41113 and you will find
Old 12-31-2012, 01:49 PM   #8
marioa111
so if I where to purchase a 2221-2010 i wouldn't be able to use the pinions?
Team ALIGN USA/ENTERPRISE HOBBY
Team SPEKTRUM
marioa111 is offline        Reply With Quote
Old 01-01-2013, 07:22 AM   #9
LikeaNut
How about this one:
http://www.scorpionsystem.com/catalo...K-2221-1630KV/
A bit more than the desired 1300KV but with pinion and speed controller im sure you can get your desired headspeed.
LikeaNut is offline        Reply With Quote
Old 01-01-2013, 07:31 AM   #10
Camporeale54
Here is another possibility.
http://www.wowhobbies.com/agnhml450m...tor1700kv.aspx
What do you think?
Sent from my KFTT using Tapatalk 2
Camporeale54 is offline        Reply With Quote
Old 01-01-2013, 11:05 AM   #11
baui2000
True. Also, I don't feel any shortage of power on 4S powered Mini running VBar governor. It's pretty amazing still, after months of flying this setup
Tom
RCHN#233 | Lynx Heli Innovations Team
Protos Max | Goblin 700
| Goblin 570
baui2000 is online now        Reply With Quote
Old 01-03-2013, 10:46 PM   #12
west5500
I use the MSH branded Scorpion 2010kv motor in a 4S setup. Turnigy batteries (2200 mah 30C) seem to work well. I use a 15T pinion, MSH Brain, as well as MKS DS95 and DS95i servos. I really like this setup.
At the time I built this heli, I wanted it to be a 6S setup, but could not find the MSH 1300kv motor. Same problem then as now, I guess. Someday, when the motor appears again, I may pick it up, but I'm not terribly worked up about it. I really like my Mini Protos the way it is. A very nice flier indeed.
SAB Goblin 500: MSH Brain, Kontronik Jive & 600-12
MSH Protos 500: Stretched, MSH Brain
MSH Mini Protos: Stretched, MSH Brain
west5500 is offline        Reply With Quote
Old 01-08-2013, 07:47 PM   #13
spykez
No 6S locally so I just got a 6S from msh-direct (for a stretch).
[Off-topic]
First order with msh-direct, he was the first guy I hit up on the net yesterday that had all the stuff I needed. I pretty much received an email that he had shipped it.... in a blink... whoa... Well impressed. Thanks!
Got a stretch kit with the new blades. What's the deal with msh and SAB falling out anyway? Sorry I'm late to the party about this. Is it because of the soon-to-come 700 and SAB's 500 and possibly 450 size ones?
Still in exile. FML.
spykez is offline        Reply With Quote
