Go Back   HeliFreak > R/C Helicopter Support > 800 Class Helicopters
800 Class Helicopters 800 Class Helicopters
Old 12-17-2012, 05:55 PM   #1
hidaven
Default Trekker slow tail wag in hover?
Racking my brain on this, checked for binding, servo seems fine, tried bumping the gyro gain up to 89% then down to 40% and its still there. Seems to get better as the rpm increases. If I hit a hard pitch pump or pyro it holds solid.......anyone else getting this or have a suggestion?
TIA, Dave
hidaven is offline        Reply With Quote
Old 12-18-2012, 09:58 AM   #2
HeliGriff
TIA, Dave
Sorry I do not but, my 600EFL does the same thing in a strong wind. I just figured it was weather-vaining. Tail holds well otherwise. A video that I watched suggested to set the TX gain first, then adjust the pot on the gyro (BeastX) second. I'll try to find the video again and post it.
ALIGN T-REX 800E DFC TREKKER
ALIGN T-REX 600EFL PRO DFC
ALIGN T-REX 450PRO DFC
Spektrum & MicroBeast electronics
HeliGriff is online now        Reply With Quote
Old 12-18-2012, 10:37 AM   #3
hidaven
No mine is slowly wagging in no wind. Tail holds though when I'm on the sticks
Old 12-18-2012, 10:47 AM   #4
raptorz499
The pot on the beast is for how hard it stops when lettin go of the rudder input! Is everything perfectly silky smooth on all the tail linkage?
raptorz499 is offline        Reply With Quote
Old 12-18-2012, 11:01 AM   #5
hidaven
yeah like 2 ice cubes sliding over each other.....tried the gyro gain up and down, gets better when its higher gain and higher RPM but still there......
Old 12-18-2012, 01:59 PM   #6
HeliGriff
I found this video. It is for a BeastX, not V-Bar. However, I feel it is accurate for most FBL systems in terms of the sequence for setting up the tail gyro & gains. The backwards flight test is interesting. It's worth a shot anyway..
http://www.youtube.com/watch?feature...&v=roU6a3UlS7U
Old 12-18-2012, 02:51 PM   #7
raptorz499
How is beast mounted? Not the stock pad I hope!?
Old 12-19-2012, 10:57 AM   #8
HeliGriff
I use two layers of the 3M self adhesive (red). Throw the BeastX's sticky-pads away!
