Go Back   HeliFreak > R/C Electronics Support > Eagle Tree Systems
Eagle Tree Systems Onboard data loggers, telemetry, and OSD support
Old 12-17-2012, 06:40 PM   #1
satgod
Default V4 E-loger
I finally put my V4 elogger and OSD-pro on my quad today, first time day in 2 weeks i've had time to mess with it
I went with eagletree over ezosd for the ability to completely customize my hud and the artificial horizon.
ezosd = easy and clean (ALOT less hardware and wires)
eagle tree = Alot more options and configurations, but ALOT more wires and hardware
So after 2.5hours of mounting, hiding wires and making leads to connect up everything its finally done and as clean as I can see it getting for a long time
Now I power up and it works but I got white horizontal lines (from text wash out) and no artificial hud
I know there are settings in the unit to change this
but dow exactly do you get to the menu
readying the manual has gotten me no where (its actually just a quick reference card)
also do you have to have the altitude microsensor for art horz or will it work off of gps only
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 12-17-2012, 09:39 PM   #2
RotaryBliss
HI, for starter's are you using the USB computer interface? thats the only way I've programmed mine. I have never used the on screen menu..
RC field rep.
Team Tail-in / Helifreak Elite Bacon Awareness Committee
RotaryBliss is offline        Reply With Quote
Old 12-17-2012, 10:01 PM   #3
satgod
used usb and finally figured out the sticks
didnt have a option in the usb software for hud
if theres a easy well please tell
my gps fix takes a long time as well
its the new v4 unit, all of it is
