Old 12-18-2012, 07:25 AM   #1
TTRAPTOR903D
Default Self Contained Nitro Starter
Can anyone recommend an all inclusive nitro starter set up that could use a 5s lipo or stronger?
Im done with the align starter. I saw Bobby Watts use this contraption but dont know what it is . Any Sug ?
700N 3GX DFC HEAD OS91HZR HAT SB20FH2
700E 3GX TP5000 45C 700MX CCHV160 EDGE693FBL BECPRO 8V
600E PRO 3GX 450 PRO 3GX KDE BLING MCPX STOCK
RAPTOR 90 3D OS91HZ HAT SB20FH2 JR8917HV AR7100R 8V GY401 TAIL 9254 5V
TTRAPTOR903D is offline        Reply With Quote
Old 12-18-2012, 07:36 AM   #2
JasonJ
Sullivan with finer edge Makita 18v drill batt conversion. It's the last starter you sill ever need. I have an Align and it works well for my OS 55. I also have a Sullivan with a 4s 4000 mah batt as a backup in case the align dies or I get a 700.
Velocity 50 FBL w/Beastx, T-rex 500ESP, 450 size scale UH-1N, T-Rex 450, mCPX BL, mCPX, Traxxas QR-1 micro quad, JR X9303, Realflight G3.5, AMA# 923167, Vice Prez Farragut Flyers
JasonJ is offline        Reply With Quote
Old 12-18-2012, 07:41 AM   #3
TTRAPTOR903D
It looks like they come with that cup setup. What are you using as a shaft coupler ?
Old 12-18-2012, 07:46 AM   #4
RogerRabit
What is wrong with the align?
Just bought one for the 700.
I tested it before from a buddy and it worked good.
For very cold temperatures i use a 120 starter on 20Nicads.
RogerRabit is online now        Reply With Quote
Old 12-18-2012, 08:00 AM   #5
Rahulgaba
Love the align starter. 40 degrees outside and fires my 55 in one whirl!! Loving it!
Whiplash 90E Scorpion HKIII 4035-560 and MSH Brain
WARP 360 IKON
VIBE 55 IKON Compass TRACX head
JR X9503
Gaba
Rahulgaba is offline        Reply With Quote
Old 12-18-2012, 08:27 AM   #6
B.R.C.
i use a hobbico 180 on a 4s 5000 starts my 50,55,37 no prob and dont have to charge but once every month or two. as far as the cup goes i removed it and bought a maverick starter shaft with a one way. and shimmed the difference in size on the shaft coupler to the motor shaft with brass tube.
Trex600N Pro..Trex600N..Trex500..Trex450SE V2..
JR Venture 30..
B.R.C. is offline        Reply With Quote
Old 12-18-2012, 08:45 AM   #7
fastone93
I use a Hangar9 HD starter with a 3s lipo, starts my 105 like a 37...
clip the leads off of the starter and leave enough to solder on a deans connector. Velcro a 3s 2200mah lipo to the starter, connect the deans, go fly (half the summer before you need to charge...)
I also hate using a cup adapter, so I use the coupler that bolts to the starter shaft...
Trex 700 dfc (OS 105HZ-R, Hatori Pipe, MKS HBL950, Futaba CGY750, MKS HBL980, Rail Mains, Rail Tail Blades)
fastone93 is offline        Reply With Quote
Old 12-18-2012, 08:51 AM   #8
flyinghigh450
http://www.helifreak.com/showthread.php?t=480295
Team Align
flyinghigh450 is offline        Reply With Quote
Old 12-18-2012, 11:20 AM   #9
Danal Estes
+ a million on this one. When other folks starters at the field are dead, or wont crank that huge displacement (whatever) that's being balky... out comes the sullivan / finer edge / makita.
Besides, its an excuse to buy another drill, because you have the batteries and charger...
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Rhino 4900; SH frames are ~1 Lb lighter than Align 700E kit
Trex 700N - 7100R/JR8717@8V/GY611
About a dozen more, including 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G
Danal Estes is offline        Reply With Quote
