Old 12-18-2012, 01:07 PM   #1
MX48
Default Protos ESC
Looking for a cheap ESC for my Protos as I burned out my CC100 in a nose down crash.
Are any of these acceptable? I only do mild 3d. Some are used prices and some are new.
Hobbywing Pentium 80-$35
Turnigy dlux 100A-$35
Turnigy kforce 100A-$60
Hobbywing Platinum Pro 80-$50
Thanks for any help,
Moto
MX48 is offline        Reply With Quote
Old 12-18-2012, 01:23 PM   #2
Dr. M
I recommed you go with a Turnigy YEP 80A - great soft start and amazing GOV.
Definitely not the Dlux or Kforce, they are pretty poor performers. I've never use HWs, but they seem to have a solid following.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is online now        Reply With Quote
Old 12-18-2012, 01:30 PM   #3
MX48
I assume you mean the Hobbyking YEP80 and that was my first choice but it is out of stock and then has to come from China.
Hopefully someone will chime in on the Hobbywing.
Old 12-18-2012, 04:11 PM   #4
shadco
Moto
Which Gyro?
The Hobbywing Platinum is supposed to work well with Vbar's and Skookum's governors.
Added plus they didn't steal their technology from YGE
Diabolo 550 Vbar NEO : Diabolo 700 Vbar NEO: MSH Protos MAX V2 Vbar NEO : Logo 600SX V2 Vbar NEO : Compass 6HVU Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control ==> Jeti DS-14/BrainV2: Citizen 735
shadco is offline        Reply With Quote
Old 12-18-2012, 04:24 PM   #5
MX48
Which Gyro?
Brain.
Old 12-18-2012, 07:29 PM   #6
Dr. M
The Turnigy Plush series is another option with good results reported on RCG. No data on usage with the Brain tho.
Goblin Speed | iKon
Old 12-18-2012, 09:33 PM   #7
desertstalker
Brain.
Use a HW ESC and the Brain gov.
The YEP escs are not so great when used with a FBL governor, they kick hard on startup.
-DX8
Old 12-19-2012, 01:27 AM   #8
rossk
Is there any difference between YEP and YGE?
I'm using brain gov on my YGE 90, I don't get a kick on startup, but it is a fairly quick spool time, smooth tho, p500 might rotate 10 deg at most, if at all...
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote
Old 12-19-2012, 01:50 AM   #9
Dr. M
Allegedly, the YEP is a clone of an older, non-production version of YGE...
Goblin Speed | iKon
Old 12-19-2012, 04:42 AM   #10
Mikej
YEP 80 / 100 (very similar prices) or very strongly consider the HobbyWing Platinum 100A / Turnigy K-Force 100 - this is the same ESC that Gaui use re-branded on the X5
Mikej is online now        Reply With Quote
Old 12-19-2012, 02:35 PM   #11
MX48
Thanks guys.
Looks like I am going with the K-Force.
Moto
