Old 12-18-2012, 12:07 PM   #1
MX48
Default Protos ESC
Looking for a cheap ESC for my Protos as I burned out my CC100 in a nose down crash.
Are any of these acceptable? I only do mild 3d. Some are used prices and some are new.
Hobbywing Pentium 80-$35
Turnigy dlux 100A-$35
Turnigy kforce 100A-$60
Hobbywing Platinum Pro 80-$50
Thanks for any help,
Moto
MX48 is offline        Reply With Quote
Old 12-18-2012, 12:23 PM   #2
Dr. M
I recommed you go with a Turnigy YEP 80A - great soft start and amazing GOV.
Definitely not the Dlux or Kforce, they are pretty poor performers. I've never use HWs, but they seem to have a solid following.
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is offline        Reply With Quote
Old 12-18-2012, 12:30 PM   #3
MX48
I assume you mean the Hobbyking YEP80 and that was my first choice but it is out of stock and then has to come from China.
Hopefully someone will chime in on the Hobbywing.
Old 12-18-2012, 03:11 PM   #4
shadco
Moto
Which Gyro?
The Hobbywing Platinum is supposed to work well with Vbar's and Skookum's governors.
Added plus they didn't steal their technology from YGE
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar
SAB G500 Savox 4050 KST/MKS HV YGE HC3SX
Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8
shadco is offline        Reply With Quote
Old 12-18-2012, 03:24 PM   #5
MX48
Which Gyro?
Brain.
Old 12-18-2012, 06:29 PM   #6
Dr. M
The Turnigy Plush series is another option with good results reported on RCG. No data on usage with the Brain tho.
Old 12-18-2012, 08:33 PM   #7
desertstalker
Brain.
Use a HW ESC and the Brain gov.
The YEP escs are not so great when used with a FBL governor, they kick hard on startup.
-DX8
Old 12-19-2012, 12:27 AM   #8
rossk
Is there any difference between YEP and YGE?
I'm using brain gov on my YGE 90, I don't get a kick on startup, but it is a fairly quick spool time, smooth tho, p500 might rotate 10 deg at most, if at all...
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp
MA Whiplash - Kosmik 200, Pyro 700
Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360
MSH Brain Spektrum DX8
rossk is offline        Reply With Quote
Old 12-19-2012, 12:50 AM   #9
Dr. M
Allegedly, the YEP is a clone of an older, non-production version of YGE...
Old 12-19-2012, 03:42 AM   #10
Mikej
YEP 80 / 100 (very similar prices) or very strongly consider the HobbyWing Platinum 100A / Turnigy K-Force 100 - this is the same ESC that Gaui use re-branded on the X5
Mikej is offline        Reply With Quote
Old 12-19-2012, 01:35 PM   #11
MX48
Thanks guys.
Looks like I am going with the K-Force.
Moto
