Go Back   HeliFreak > R/C Helicopters > Aerial Videography and Photography > Realtime Video and FPV
Realtime Video and FPV Discussions of receiving video in realtime from the aircraft
Old 12-18-2012, 01:50 PM   #1
daneger21
Default Goggles or monitor for fpv?
Just getting started in this side of the hobby. Ive been fling heli's for years and wanna give fpv a shot but with a multirotor for stability reasons. Ive been looking at dji f450 with naza gps for flight control. But as for video(tx/rx/etc) im not sure which route to go...
Do you recommend goggles or a monitor for viewing, and why? Pros?Cons?
No I didn't misspell Daneger, my name is Dane..get it?
"Flyin' high again..." -Ozzy Osbourne
daneger21 is online now        Reply With Quote
Old 12-19-2012, 09:13 AM   #2
jlharv
1 vote for goggles
Pros:
Bigger field of view (equal to a 55" tv)
No glare
OSD looks great
Blocking out the rest of your surroundings really makes you feel as if you are in the cockpit.
Cons:
Cost (good goggles are around $300)
To me it is worth it, for the reasons listed above and since this is a one time purchase that you can use with all future FPV projects. It's not like you have to buy a new set each time you build another bird.
John
nCPX ,mCPX BL, 130x - T-Rex 500ESP DS510, mini VBar, 13T
T-Rex 600ESP 12s, scorpion 4025 630, VBar, DS650, DS610, 14T- T-Rex 700E V2 VBar
jlharv is online now        Reply With Quote
Old 12-19-2012, 09:57 AM   #3
daneger21
I was looking at this kit...
http://www.readymaderc.com/store/ind...roducts_id=781
Is this over the top? Or like you said then ill have them. It does supposedly come with everything i need which is nice for a newb. Is that a good price? Good hardware? Electronics? Etc?
Old 12-19-2012, 12:50 PM   #4
jlharv
That is the kit that I got. The only things that I changed was to remove the camera and replace it with the gopro cable because I want to record HD video. I also added the OSD. But that is obviously not needed, I just liked the idea of having my altitude, speed, battery voltage, direction to home on the screen. I just had a little extra Christmas money and treated myself
I do not think that is to over the top either. I have the belief that if you buy good stuff, you only have to buy it once. I thought about going cheap and figured I would spend more money in the long run and end up buying this in the end any way.
I don't want to present myself as a FPV veteran though. I just built this and only tested it once. I am keeping myself on the ground until I get my license. But the test I did of it worked well. I did try a few of my friends goggles before I made the decision.
John
Old 12-19-2012, 03:40 PM   #5
satgod
I have that same setup and its nice
heres a video of my first real fpv flight with it
the 5.8 is good but dont get behind anything or it can wash out
on my second REAL fpv flight I got about 3 city blocks away in the subdivsion and decended down behind a 2 store house and lost my video feed
quickly hit the return to home switch on the radio and once it was back up high my video came back and I took over again
I really recommend some sort of OSD I went with eagle tree because I wanted the horizon indicator and its VERY configurable.
It also begins to take up room when you start adding alot of sensors
ezosd is just that easy but not as robust as eagle tree is
but at least get something with a home location function (arrow points to home)
its way different when your looking from the camera view and without a return home arrow it can take some time to find your heading home, if you do at all
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 12-19-2012, 08:02 PM   #6
daneger21
Hey thanks guys for chiming in. No need to be experts here, just looking for opinions. Everyone thinks different, and uses their equipment alittle differently, im just happy that guys are actually using this stuff and happy with it.
I was thinking about keeping this setup as is for the live feed aspect, but also mounting a go pro for hd video while utilizing the dji stabilization output for a gimbal.
Old 12-19-2012, 08:24 PM   #7
satgod
you can use the gopro for video feed and recording and loose the weight of the extra fpv camera, thats how I do it.
Old 12-19-2012, 08:29 PM   #8
daneger21
I thought it was possible. But is there any lag using the gopro? I thought i read once that some had a lag. Maybe im wrong, hell i dont even have a gopro yet . Is there any certain models i should look at without breaking the bank yet again?
Old 12-19-2012, 09:50 PM   #9
jlharv
The new GoPro Hero 3 is HDMI out and you can get an adapter that will work, but like you said, the lag makes it pretty bad.
The good news is that the Hero 2 (that is what I have) works well. I think there is a little lag, but it is not very noticeable. I think I read some where 10ms. I think most would not even notice it. And since the Hero 3 came out, the 2 can be had for cheap. And they still do a really nice HD video.
Here is a video from my Hero2 (same quad but flown line of site not FPV).
Select 1080 to see the detail, and remember that is after youtube compresses it.
This is my buddies house that we fly at. The glider in front of the hanger is FPV. This is great FPV location.
John
Old 12-19-2012, 11:10 PM   #10
daneger21
Very nice. After watching your video i did a search on gopro fpv lag. I think your right, the lag is technically there but not so much to cause major issues. Ill give that route more of a thought!
How often do you fly full fpv with your gopro setup? Compared to line-of-site?
thanks for sharing
Old 12-20-2012, 02:53 AM   #11
sl4ppy
The bad thing about GoPros is that if they lock up or crash (which they are prone to do), you're SOL for seeing anything. A dedicated flight cam will never lock up or crash and weighs but a few ounces.
Fly with both if you must have HD recording.
sl4ppy is offline        Reply With Quote
Old 12-20-2012, 05:49 AM   #12
jlharv
thanks for sharing
I mostly fly 3d helicopters, so I find quads pretty boring. So the plan is to only use it for FPV. That flight was just to test the gopro.
Mine locked up the last time I flew it. The video feed keeps going, just the camera locks and you can not push any buttons and have to pull the battery to reset it.
John
Old 12-20-2012, 03:38 PM   #13
salience
Default gargoyles
There goggles seem to be a better deal than the popular FatShark, better specs, corrective lenses included...
http://www.rangevideo.com/index.php?...fcebc6812faea5
Anyone try these?
salience is offline        Reply With Quote
Old 12-20-2012, 08:04 PM   #14
satgod
my gopro has yet to lock up but I think that has alot to do with firmware and keeping your sd card clean
as for lag the gopro 3 has a small lag and the hero2 might have some but I use my hero2 and cant see it I record at 720p 60fps could do 1080p 30fps but 60fps is nice
I can NOT honestly see how anything in the milli-seconds can even be perceived by the human eye
a dedicated cam does give one a sense of security I guess but if I get into trouble I just flip the swith on the radio and she climbs up and returns home or at least close enough for me to take LOS control . I did loose my video feed behind some buildings (5.8 doesnt penetrate well) and I hit the return home and when it cleared the building and I got video back I went back to flying again
Old 12-20-2012, 09:06 PM   #15
satgod
for a stand alone camera system you might look at this
http://hobbywireless.com/index.php?m...roducts_id=827
full 1080p at 30fps
full 720p at 60fps
and it can record video using a microSD card
its a hero2 without the extra weight
Old 12-20-2012, 09:37 PM   #16
daneger21
full 1080p at 30fps
full 720p at 60fps
Not bad, ill look into that!
