Old 12-18-2012, 03:18 PM   #1
Scotty T
Default Can the 300 handle a stronger motor?
I hear a lot about the main shaft shearing off and other things.
Could this thing handle a stronger motor?
Is it even worth upgrading the motor?
Addicted to Helis
Trex 900 DFC Ultra Combo OS HZ 195 Hyper , Goblin 1200 84S Flybared
Scotty T is offline        Reply With Quote
Old 12-18-2012, 03:51 PM   #2
ahahn
AFAIK, the shaft isn't shearing off (when a shaft does break) due to motor torque. It seems to be more related to some type of flexing issue.
I'll leave it at that, except to note I haven't had a shaft breaking problem, but some guys have.
ahahn is offline        Reply With Quote
Old 12-18-2012, 04:07 PM   #3
xpantz
I have a 2213-14 working just fine.
I did snap a mainshaft when I first installed it.. but it was almost certainly due to vibration caused by other things.
Since a rebuild (last week) with a Lynx frame brace I have about 25 flights (4-5mins) @3400 rpm and no problems.
It's a different heli with a better motor. Smoother, quieter, higher rpms, more powerful... less buzz and more woosh!
I wouldn't try putting too much power through that shaft but it seems to be able to handle a bit if everything else (vibrations mostly) is ok
xpantz is offline        Reply With Quote
Old 12-18-2012, 04:10 PM   #4
Chris Gardill
YMMV and I can only speak for myself, but I would respond yes to both questions. I have about 85 flights now on the Don's Wicked RC motor that Dylan sells and it's a great improvement IMHO. I'm currently running it with a HiModel Cool 33a ESC that Dylan put together for me for testing but I've also run it with a Castle Phoenix 25 and Park BEC. I think both of those ESC choices are nice improvements over stock because of the governor capability.
My only personal experience with a broken shaft is the one crash that my 300x has sustained. Other than that, mine have held up well although I'm not suggesting others haven't experienced problems as they clearly have. I have flown either Dylan's braces or now the Lynx braces since I've owned the heli so I'm unsure whether Blade has made the issue better or whether the braces have helped that. Either way, mine is working well.
As far as the Wicked 4800kv motor, it's better balanced, quieter, and has a noticeable increase in power and torque when governed compared to stock and well worth the money IMHO. They're a bit hard to come by based upon the size of both Don's and Dylan's shops but they're a great motor. Others seem to have good results with a couple of different Scorpion motors but I haven't tried them personally so I can't make a recommendation on them personally.
Synergy E7SE (KDE 700XF-495) (under const.); Synergy E5 (KDE 600XF-530); Goblin 500 (XNova 4020-1200); Gaui X3; MSH Protos; Blade 350QX; Blade 200QX.
Chris Gardill is offline        Reply With Quote
Old 12-18-2012, 04:52 PM   #5
Scotty T
So is there a drop in replacement that someone can recommend?
I don't want to get caught up in modding, expensive upgrades, etc. I'd be willing to swapping out the motor and the esc.
Thoughts?
Addicted to Helis
Old 12-18-2012, 04:58 PM   #6
65L88
Thoughts?
The Wicked is almost a direct drop in. All you need to do is direct solder it in or add your own bullet connectors. And if you order one from Dylan, it'll come with a 9T and a 10T pinion.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- 300X - 130X X3- mCPX brushless X3-Nano cPX X 2- Nano QX
65L88 is online now        Reply With Quote
Old 12-18-2012, 05:07 PM   #7
mixfisto
Chris G,
I just got around to installing the Wicked motor with the YEP 45a esc. I was hoping to have more power than stock, but honestly, I think I have less oomph now. I have it governed at 85%.
Trying to figure out what isn't right here...
What throttle speed are you governing at?
mixfisto is offline        Reply With Quote
Old 12-18-2012, 05:20 PM   #8
65L88
Originally Posted by mixfisto View Post
Chris G,
Make sure your throttle endpoints are good. I made this mistake with my Ice Lite, and I was running about 65-70% rpm with 100% throttle. The thing was a total dog. Got it sorted out and it's much better. 80-85% feels about like stock did at 100%.
MARTY
Team Newb pilot
Old 12-18-2012, 05:27 PM   #9
ahahn
Thoughts?
Why change at all? The stock motor and ESC work fine, unless you are looking for something else.
Old 12-18-2012, 07:10 PM   #10
mixfisto
Thanks Marty... I'm pretty sure now that I didn't set up the ESC correctly. Will retry the setup and try again.
Ahahn, the reason I got the Wicked motor and YEP esc, is that my motor basically vibrated itself to death...and my esc broke on a heavy crash. I replaced the stock parts with much better aftermarket parts and also saved money doing so
Old 12-19-2012, 04:47 PM   #11
Chris Gardill
Definitely +1 on the endpoints as I've fought the same fight with my Phoenix 25 prior to switching to the HiModel. It should be a noticeable difference in pop on a 10T pinion. I'm running a different ESC but I believe my IU2 where I tend to fly it at is set at 85%. Good luck.
