Old 12-18-2012, 02:57 PM   #1
Scotty T
Default Good Main Blades
Will these work or are they too long?
http://helidirect.com/edge-253mm-pre...es-p-27541.hdx
I know horizons are 245 these are 253.
Thoughts?
Addicted to Helis
Trex 900 DFC Ultra Combo OS HZ 195 Hyper , Goblin 1200 84S Flybared
Scotty T is offline        Reply With Quote
Old 12-18-2012, 03:03 PM   #2
Chris Gardill
Different blade manufacturers measure blade lengths differently. Some measure tip to tip and others measure the length from the bolt-hole to tip. These Edge blades are nice blades and what I am personally running on my 300X right now. They're well balanced and look nice and I also feel they have a bit more pop than the stock wood or CF blades do. They are "slightly" longer than the stock CF blades but I haven't measured them. They are not "too long" to work properly in any event.
Although I've not personally tried either the Microheli or Gaui blades that fit the 300x and seem to also get good reviews, these blades and the SAB 255 blades work very well and I can recommend either of them over stock.
Team Newb Pilot
450X (6S Scorpion 2221-2010, Spektrum H3000, MKS DS95i, Ice Lite 50); 300X (Spektrum H3000, Hyperion DS11GCB, HiModel Cool 33A/Don's RC Wicked 4800kv); TRex 250 Pro DFC (250MX, MicroBeast, Phoenix 25); 130X HP10S; mCPX BL; NanoCPX.
Chris Gardill is offline        Reply With Quote
Old 12-18-2012, 03:49 PM   #3
Scotty T
I really like the SAB's , Can't find them in stock anywhere.
Addicted to Helis
Old 12-18-2012, 04:12 PM   #4
mixfisto
I really like the Gaui's...much better than Blade CF's.
mixfisto is offline        Reply With Quote
Old 12-18-2012, 04:15 PM   #5
65L88
I haven't flown the Blade cfs, but I really like the way the Gauis perform.
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- Trex250 DFC fbl - 300X - 130X X3- mCPX brushless X3
65L88 is offline        Reply With Quote
Old 12-18-2012, 06:13 PM   #6
mixfisto
Yeah, don't even bother with them! For the same price, the Gaui's kick their a** . Plus they look a lot better IMHO.
Honestly, the Blade CF's should be about $15 a pair...crazy that they charge 3x the price of the woodies for only a slight improvement.
Old 12-19-2012, 12:24 PM   #7
petedee
Most of these should be $15-20, the MH blades are crazy priced too.
I am hoping that we will see similar quality and pricing for 300X blades as the Trex450 blades, you can get quite good CF blades for the 450 from under $10. HobbyKing to the rescue soon I hope.
petedee is online now        Reply With Quote
