Old 12-18-2012, 03:06 PM   #1
dantemcc
Default sk powerbus, what do i need to know?
Guess I'll spend the money to buy powerbus for my units and maybe that will stop the tail loss issues I'm having with them. Some have told me it may be due to brownouts, which I'm hesitant to believe as I never loss my cyclic controls, but whatever. I'll try and see. I'm about to buy them from helidirect. They'll be used with a futaba sbus. do i need to purchase anything to go with it or?????
Why does everyone keep calling me Dan? My name is Dante
dantemcc is offline        Reply With Quote
Old 12-18-2012, 03:35 PM   #2
georgi UK
=] the power bus is not intended for tail loss?? on it's own it is no different to what you have now, the SK tail is the best out there, you can bet your house on that.
more than one heli with the same issue, usually says handset / RF? are you feeding the S-bus with enough juice?
georgi UK
georgi UK is offline        Reply With Quote
Old 12-18-2012, 03:39 PM   #3
dantemcc
I know the sbus is not intended strictly for the tail, but as told by another member buying one for all my helis might negate the problem as maybe the power being drawn may spike or something. I have my CC BEC PRO set at 6.0v as I'm running DS610 and DS650
Old 12-18-2012, 03:47 PM   #4
georgi UK
=] turn on logging, lets see the voltage drops, or where the issue is? use this uploader
= http://www.filedropper.com/
georgi UK
