Old 12-18-2012, 04:16 PM   #1
What
Default Main Gear/Shaft glue?
When I bought it new there was some black "glue" on the main shaft under the main gear.
To keep the main gear in corret position.
Can you buy this any where?
Thanks!
What is offline        Reply With Quote
Old 12-18-2012, 08:15 PM   #2
jbilliter
I think it is very similar to Liquid Tape, available at Home Depot and probably similar stores. Liquid tape works well because I have to scrape some of it off when I do want to remove the gear.
NCPx+ Mild BL, MCPx, EXI 450 pro, HK250GT/BladeSR, MSR, DX6i
jbilliter is offline        Reply With Quote
Old 12-18-2012, 08:17 PM   #3
kingmeow
You can use a bunch of stuff for that:
  • Caulking (latex or silicone, any color)
  • Goop (or Shoe Goo or whatever they call it now a days)
  • Elmer's white glue (or Carpenter's yellow)
  • Hot glue gun
There's really nothing special about the black factory stuff.
kingmeow is offline        Reply With Quote
Old 12-20-2012, 04:55 PM   #4
ElektroTrainerS
Hi,
after installing the AD Mild Kit I havenīt glued the main gear. It works
ElektroTrainerS is offline        Reply With Quote
Old 12-21-2012, 11:09 AM   #5
captdave221
So a drop of thin CA I used was a bad idea?
captdave221 is offline        Reply With Quote
Old 12-21-2012, 01:42 PM   #6
mtwarych3@msn.com
Default Bees wax or R/C56
I cannot say whether it works on helis, but bees wax is a superb adhesive for non permanent joints. R/C 56 was desighned to glue canopies onto R/C aircraft only drying to a high tach non permanent bond. With my helis i would use bees wax. Good luck.
JW
mtwarych3@msn.com is online now        Reply With Quote
Old 12-21-2012, 08:29 PM   #7
kingmeow
I don't think so but the other recommended "adhesives" are easier to remove in the further if need be.
Old 12-21-2012, 09:46 PM   #8
tchilds
I CA my main gear on too. It works fine and comes apart too just fine.
The gear fits fine with no glue. I think the reason they put that dab on there is to balance the main shaft, not to hold the gear on. The main shaft in the nano is perfectly balanced except for the main gear's flat. The rubber would solve this.
I've had metal parts completely demonlished by something that was out of round before in the rotating assembly. Balance is nice even though not necessary.
tchilds is offline        Reply With Quote
