Old 12-18-2012, 04:25 PM   #1
nick.m
Default sk540 tape
new to the sk540 but with the beast x every 1 seems to use 3m tape to fasten it down,,now got my new 540 today and the 2 squares of white tape that came with it are very thin and quiet similar to 3m tape ,,do people use it or just go with the 3m
thx nic
nick.m is offline        Reply With Quote
Old 12-18-2012, 08:36 PM   #2
Larry227
Many are using the grey 4011 3M outdoor tape. I am too but still haven't had a chance to maiden mine since installing it.
Compass 6HV - SK540 - MKS HBL665/669
Trex 500 ESP - SK540 - 510's/BLS251
DX8 / Phoenix / Persistence
~"See the heli, fly the heli"~
Larry227 is online now        Reply With Quote
Old 12-18-2012, 08:38 PM   #3
Larry227
You can also read this thread and then make up your mind http://www.helifreak.com/showthread....=mounting+tape
Old 12-19-2012, 10:43 AM   #4
georgi UK
=] Nic hi, the supplied white tape works really well, I would start on this for your first flights, if you are having any issues at least we know the tape is not it!
and welcome to the 540 club!
georgi UK
georgi UK is online now        Reply With Quote
Old 12-19-2012, 10:50 AM   #5
nirtza79
georgi,
Not to hyjack the thread or anything, just to make it clear to me..
Use only the white tape or also the metal plate and if so what did you find works the best?
Trex 450 Sport V2 TT FBL SK 540
DX6i
nirtza79 is offline        Reply With Quote
Old 12-19-2012, 10:58 AM   #6
georgi UK
Originally Posted by nirtza79 View Post
georgi,
=] hi, the metal plate is used on the 720, the 540 doesn't need this, so yes, thin white tape only.
georgi UK
Old 12-19-2012, 11:09 PM   #7
nick.m
thx for the advice guys ,,i will try the included tape and see how it goes
Old 12-20-2012, 10:12 AM   #8
gitbse
General rule of thumb I've learned with the 540, is the harder the better. I use a single layer of gel tape, and it has no free motion at all. The 540 flies better hardmounted, and you can actually notice a difference when it's not. I saw a couple of 540's actually glued onto a frame at ircha.
Skookum Support Rep
Mini Protos SK540,Rave ENV SK540, 4525 LE
Runways are for models and wings are for fairies.
gitbse is online now        Reply With Quote
