| 300X Blade 300X Helicopters Information and Help |
Just got the word. Going to Ampdraw to order since it seems to be the cheapest. I see lots of aluminum replacement parts. Are they good/bad? I know I hated the plastic swash from the mcpx, I may go ahead and get the aluminum one for the 300x.
I hated the dual motors on the mcpx. Seemed like I could never escape tail problems. I hope a belt driven tail will be a better experience. - Victor. |
I just had to click to make sure this wasn't a joke...
I'd hold off on dumping money on swashes and such until you get the thing off the ground as the base is an excellent starting point unlike the plasticy issues with the micro parts. The included swash on the 300X is decent just be aware of some of the structural experiences that some have had.
Beating the air into submission... one Blade® at a time! Lynx Heli Innovations Team Pilot SilentDRC.net -The Order of Brushless Witnesses |
Some have had mixed reviews on the metal swash, as it requires a re-setup of the beastx because its limits for binding are less than the stock swash. There is no problems with the stock one..
My recommendation: Balance the woodie blades, maybe do the shim mod on the rear servos and fly stock.. You won't be disappointed.. The 'shim mod' is where you just take thin credit card like material between the servos so they fit as snugly as possible. This adds just a little extra stiffness to the upper frame. Its cheap and easy to do. Check out finless bob's videos on how to balance blades.. Also be sure to follow the addendum instructions for the lower top throttle with the wood blades..
Blade 300X, mCPX, FPV Raptor, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX7s. |
I'm still all stock and loving this bird.......
/MSRX, MCPX, Nano, 1SQ, several 130x, Gaui X2, 300x, 450x, DX8, Harley Road King To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. "It's not getting any smarter out there, you have to come to grips with stupidity and make it work for you" - Frank Zappa |
Awesome, Glad to hear it fly's good stock. By tons of money I meant because I love to get to 'excited' with it and push myself beyond my limits. Which means lots of broken stuff!
Also maybe this is a question for another forum, but I need a good battery charger. I hate waiting long for them to charge. There are so many options, what are you guys using for multiple packs at a time. thanks - Victor. |
#6 |
Chargers you can get whatever you want but these are excellent quality chargers and can do multiple packs:
http://epbuddy.com/index.php?main_pa...ffjvgmq2f80pg1 I use this paraboard: http://epbuddy.com/index.php?main_pa...roducts_id=109 Hope that helps.
#7 |
I use a maglev blade balancer, love the thing. They sell them at wow hobbies for about 35 bucks or so. A little expensive, but to me, totally worth it.
In addition (if u can afford it), I'd suggest buying a parts lot or a spare complete airframe (minus beastx) from the for sale forum. This'll save you a LOT of money in the long run (I did both). It's nice to have a spare airframe for reference too till you learn the ins and outs of the bird too if this is your first "big" bird, like me so that one can compare it to the one you are working on. And yes, I did go buy an AR7200 later on for the spare airframe..... At least I can use it for larger birds as I progress as I got one with a satellite
#8 |
blade balancer: I just use a long bolt with 2 nuts. Works great less than a dollar.
Charging multiple batteries: epbuddy has a decent combo deal for around $150. http://epbuddy.com/index.php?main_pa...roducts_id=168 You'll also need parallel charge and balance cables, OR, a paraboard. I prefer cables rather than the board but both will work fine. Cables: http://epbuddy.com/index.php?main_pa...products_id=81 and http://epbuddy.com/index.php?main_pa...products_id=55 OR, the para board http://epbuddy.com/index.php?main_pa...roducts_id=109 If you already have access to a 300w power supply, I converted an old PC power supply for this purpose, I use this charger, and like it.. http://www.hobbypartz.com/26p-balancecharger-6200.html
#9 |
Thread title of the year! Also story of my life lol
...tappatalka2
DX6i, MCPX, CX2, PZ F4F(RIP) |
#10 | |
The tail upgrades are a different story. I have a fully upgraded tail setup on my 450X and like it, but I had difficulty balancing the metal tail grips properly on the 300X and ultimately removed them. The aluminum tail pitch lever also has the incorrect and too small screws in it where it connects with the slider and caused a huge amount of slop. I also had a lot of slop just in the linkages on the tail pitch slider so I pulled it, too. As a result of all of this, I'm back to flying a completely stock tail and it's flying great. Hope this helps but I'd avoid some of those "hop up" parts.
Team Newb Pilot 450X (6S Scorpion 2221-2010, Spektrum H3000, MKS DS95i, Ice Lite 50); 300X (Spektrum H3000, Hyperion DS11GCB, HiModel Cool 33A/Don's RC Wicked 4800kv); TRex 250 Pro DFC (250MX, MicroBeast, Phoenix 25); 130X HP10S; mCPX BL; NanoCPX. |
#11 |
Mine is almost all stock. I put in HH CF main blades, did a mod to use XT60 lipos, and did a few tweaks. The tail grip plastic base for the link ball is weak, so the aluminum tail grips may be good to get. The plastic head has issues, but apparently the metal head has its issues too.
I've never had frame bending issue, so no need for the braces. Rather than go all out for upgrades, I would focus on thorough setup, tuning, and maintenance. The good news is Blade have put out a pretty good aircraft in the 300X. I'd be looking to swap the belt, all bearings, andvthe motor at 200 flights, unless I getbearlier failures. Sent from my iPad using Tapatalk |
#12 |
Thinking about it, I have two changes from stock
1) Batteries converted to deans 2) Carbon fiber blades. That's it. Flies really smooth when I can keep control of it.
#13 |
Awesome, thanks for the feedback. Looks like I'll keep it all stock. I'll just stock up on crash parts.
