Old 12-19-2012, 11:49 AM   #1
Kev Mallin
Default Play in mainshaft to gear ???
Hi Guys
Just doing a rebuild after a small crash. Changed the main shaft, (old one was bent) it’s back together using all new hardware but I have play in the main shaft. I hadn’t noticed this before.
I’ve checked the new parts against the old and they are all the same size ect.
Can one of you do me a favour and hold your main gear then looking from the top grab your blade grips and rock them CW &ACW, can you let me know how much movement you’ve got.
It seems to me that the main shaft is turning slightly in the main gear, I’ve checked the old shaft and it’s the same, if this is standard stands a good chance that this is the reason for the shafts snapping.
Let me know if you can, I want to fly tonight.
Blade MSR, NANO, MCPXv2, SR120, MQX, SR and 300x with a DX6i
Kev
Kev Mallin is offline        Reply With Quote
Old 12-19-2012, 12:19 PM   #2
utahbmxer
I think it's normal. Mine had a lot out of the box I remember. I have since rebuilt it 3 times and I just snug the main gear bolt up a little more, not a lot but just enough that it isn't noticeable unless you grab and turn. Out of the box mine was loose enough that just by turning the helicopter the head would spin a few degrees.
They could probably make the holes in the shaft a little smaller, I bet it would reduce the broken shafts that others are getting. (have yet to break one, knock on wood.)
120SR | SR | 300X | DX6i
utahbmxer is offline        Reply With Quote
Old 12-19-2012, 12:29 PM   #3
Kev Mallin
Thanks for the info, I’ll just nip it up a bit.
I can go play .
Kev
Old 12-19-2012, 01:26 PM   #4
rc18
The main shaft and main gear hub both have too much play. Hopefully a 3rd party will develop replacement parts.
Warp 360 Green and Warp 360 Black
Blade Nano cpx, mcpx, mcpx BL, 130X and 300X
GMP Cobra and Competitor
Schluter Champion
rc18 is offline        Reply With Quote
Old 12-19-2012, 01:59 PM   #5
Kev Mallin
Need more bits, servo stripped. bu88er no 300x flying tonight.
Kev
Old 12-19-2012, 02:16 PM   #6
65L88
My 450s and my 500 have the same relative amount play as the 300X, the difference is, the play in them is damped by the OWB, so it's not as noticeable. This damping action (or lack of in the case of the 300X) could possibly be a contributor to the shaft breakage....
MARTY
Team Newb pilot
Trex 500 fbl -Tarot 450 Pro fbl- Trex250 DFC fbl - 300X - 130X X3- mCPX brushless X3
65L88 is offline        Reply With Quote
Old 12-19-2012, 07:04 PM   #7
Chris Gardill
That's an interesting thought and you might be on to something there. I hadn't ever really paid attention to what the OWB did for that issue on the bigger helis but at least my 450 behaves with a similar amount of play but the bearing almost completely masks it.
Team Newb Pilot
450X (6S Scorpion 2221-2010, Spektrum H3000, MKS DS95i, Ice Lite 50); 300X (Spektrum H3000, Hyperion DS11GCB, HiModel Cool 33A/Don's RC Wicked 4800kv); TRex 250 Pro DFC (250MX, MicroBeast, Phoenix 25); 130X HP10S; mCPX BL; NanoCPX.
Chris Gardill is offline        Reply With Quote
