Closed Thread
Old 12-24-2012, 04:48 PM   #21
NewR
I tried slowly up the throttle in normal mode (0-20-40-40-40) and no luck.
Tried 0-37-37-37-37 as suggested by Soko... No luck
Tried 0-37-40-40-40 as it worked for Larry227... No luck.
I am going back to internal YGE gov (dont have a choice do I. ) so I can get some fly time and will play more with this headache at the start of the new year.
Gravity Fighter
NewR is offline
Old 12-24-2012, 08:29 PM   #22
Jeff_Barrett
NewR ... I just programmed the SK720 and YGE 120LV on my E5 ....
Hook your Programming Card up to the YGE and plug in your power.
Change all your motor, lipo, and lvc settings and unplug your battery.
Follow this part EXACTLY or it will not save the proper mode settings:
Plug the battery in with the programming card still connected
- Go into the level 2 menu by holding both left hand buttons simultaneously and let go. The indicator light will be flashing to let you know you're in the level 2 menu.
- Go to the STARTUP SPEED option and select HELI MIDDLE
- Press ENTER
- Go to the ACT FREEW / GOV MODE option and select GOV OFF
- Press ENTER
- Press ENTER
- Press ENTER (this is not a typo that you do this 3 times)
- Go to the STARTUP SPEED option and select PLANE MIDDLE
- Press ENTER
Disconnect your battery now and unplug your Programming Card.
Now run the THROTTLE/GOVERNOR WIZARD in the SK setup software.
See if that works for you .... mine YGE has the built in sensor, but the settings should work the same, I believe.
Owner - RCHeliCanada.com
Compass || Gaui || Synergy || Walkera || DJI || Skookum Robotics || TracX || Bavarian Demon || MKS Servo
Jeff_Barrett is online now
Old 12-25-2012, 11:18 AM   #23
Luvmyhelis
Excellent post! This one should be stickied!
Luvmyhelis is offline
Old 12-26-2012, 11:31 AM   #24
NewR
Thanks Jeff! Will try that over this weekend and report back.
Gravity Fighter
NewR is offline
Old 12-26-2012, 02:45 PM   #25
heathy
The easiest way to teach the yge the throttle end points is not to use the program card at all.
1st set throttle low and high in the skookum software after stick scaling. ( 0 100 linear )
Then plug the Heli in with throttle stick at full, wait for beeps. Then pull stick down, again wait for confirmation beeps. Unplug. Now go in to prog card as norm and your done.
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep
heathy is offline
Old 01-10-2013, 01:19 PM   #26
NewR
Default Latest Update
Sorry for the late update. Heli was out due to a bad main bearing.
Followed Jeff's suggestion step by step and still didn't work.
I am giving up and don't want to mess with this anymore. I think I gave it my best effort but it just doenst like me.
Thanks to all who tried to help!
Gravity Fighter
NewR is offline
Closed Thread
