Old 12-19-2012, 04:54 PM   #1
edbme
Default (fixed) jive 80hv can't get into program mode
I'm probably missing something simple here. In my radio i have 0-100 throttle curve, my end points are 100-100, no trim. I put the throttle stick to 0, plug in battery, get 3 tones, pull the jumper and nothing happens. I get no tones and I still have control of throttle. I've been pluging and unpluging for a day now and getting frustrated. A brand new 600sx and I can't even maiden it. Thanks ed. (edit) My plastic jumper has no metal in it so It wasnt jumping anything. I used a flat head screwdriver to jump the pins and everything works fine. Only took me a day and half.
logo 600 sx vbar, 500 vbar, 700n vbar The funny thing about common sense Is It's not very common.
edbme is offline        Reply With Quote
Old 12-19-2012, 07:53 PM   #2
jhheli
Do you plan to use mode 4 ? and you shouldn't have throttle hold on when doing this, this shouldn't matter but try the outside pins closes to the end of the jive, the jumper goes deep in there to keep in mind, what radio ?
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
SAB USA, KONTRONIK, PRC, CANOMOD, PULSE ULTRA
jhheli is online now        Reply With Quote
Old 12-19-2012, 08:28 PM   #3
edbme
Yes, I want to program mode 1, 4, 9. No I'm not using throttle hold. My radio is a jr 9503. I've read the sticky above and it sounds so simple. The jumper is in all the way i believe. The only thing sticking out is the little tab. Thanks
Old 12-20-2012, 01:27 PM   #4
jhheli
Just curious, did you bind a fail safe with your radio, what fbl ?
Sponsored by :
Old 12-20-2012, 02:15 PM   #5
edbme
Yes, fail safe is all set up I just tried it out a few minutes ago. I'm running a mini vbar. Batterys are coming today and i'll be ready to go. Thanks ed
Old 12-23-2012, 12:01 AM   #6
jhheli
Your fail safe could be causing the esc not to go into programming, you should rebind it without the fail safe and then try and set up the esc the same way you have been doing, and see if that helps.
Sponsored by :
Old 12-23-2012, 12:27 PM   #7
edbme
Default Fixed
Hi jh, I got it fixed. I had a defective jumper that wasnt jumping anything. I used a screw driver to jump the pins and it worked just fine. Now if it will stop raining I can go flying. ed
Old 12-23-2012, 10:41 PM   #8
jhheli
Glad you got it worked out.
Sponsored by :
