Old 12-19-2012, 07:47 PM   #1
MiataJohn
Default ESC hold down o-ring
How many have used the semi-elasitc o-ring to secure the ESC? Mine seems kinda tight and I'm afraid of breaking the circuit board or crushing some components. I realize hook and loop is an option, but things are kinda tight and the ESC might get hung up before going all the way in.
2x Stock mCPX, 1 B/L HP05 mCPX Blade 180
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP Robird,Parkzone T-28, OXY 3, All on Dx8
AMA 732104
MiataJohn is offline        Reply With Quote
Old 12-19-2012, 07:53 PM   #2
scott s
There are 2 in the bag. I looped the 2 together like a slip knot I guess they call it for my ice lite 50. A single was way to tight and short to even try to get on. The slip not rests right in the center of the esc. Works for me LOL!
scott s is offline        Reply With Quote
Old 12-19-2012, 07:54 PM   #3
MiataJohn
Great idea. Thanks Scott. Merry Christmas.
AMA 732104
Old 12-19-2012, 08:11 PM   #4
Ty89m
I'll have to try that too. Fighting with ESC to motor wires right now, afraid ill bend the ESC motor wires to much and break the insulation... Not much room under the battery tray. I'm finding wiring to be one of the more challenging parts of this build ha!
Oxy 3 / Jeti DS-16
Ty89m is offline        Reply With Quote
Old 12-19-2012, 09:43 PM   #5
west5500
+1
SAB Goblin 500: MSH Brain, Kontronik Jive & 600-12
MSH Protos 500: Stretched, MSH Brain
MSH Mini Protos: Stretched, MSH Brain
west5500 is offline        Reply With Quote
Old 12-20-2012, 01:58 PM   #6
MiataJohn
I just tried fitting the two rings and it's waaay to loose. ESC just slides out the front.
AMA 732104
Old 12-20-2012, 02:27 PM   #7
scott s
well time to go to ace hardware and purchase some o-rings LOL!. What esc ? This works great with cc lite 50. I also have my motor wires facing rear with caps in front and motor wires looped down around the bottom of esc and exiting the front. You must solder on bullets after doing this or install esc with bullets on before you add second frame side.
Ice lite 50 was made for this heli it fits so nice!
Old 12-20-2012, 02:56 PM   #8
Ty89m
I found removing the bottom plastic tray/skids made it a lot easier to get wires where you wanted them. I too found two orings too loose, so used 4010 tape and will go shopping for the appropriate rings this weekend. This is using the stock YGE
Oxy 3 / Jeti DS-16
Old 12-20-2012, 04:54 PM   #9
CrashAddict
Default One O Ring.
What I did, was to grab that O ring with a pair of needle nose pliers and yank it through and hook it over. Not easy but it did it. One O ring is too loose if you have the wires folded very neatly and just right if you make a big mess. I was thinking some velcro dots, neat wires, and one O ring.
Mini Prtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready
CrashAddict is offline        Reply With Quote
Old 12-20-2012, 09:54 PM   #10
nynextel88
I'm actully using 2 zip ties, they run pretty flat across the battery try & are hidden under velcro. It's actually working very well.
At first I thought everytime I took off battery the velcro would start to come up but I got the zip ties as flat as I could coming over the battery tray and its working pretty well for me
nynextel88 is online now        Reply With Quote
Old 12-21-2012, 02:59 PM   #11
Chris Nifty
Geez, the single o-ring works perfectly. Just use a draw wire to pull it through.
Mini Protos, Voodoo 400, Goblin 500 Sport, Gob 550 x 3, BT650, EXO
Chris Nifty is online now        Reply With Quote
Old 12-21-2012, 03:41 PM   #12
Ty89m
Yup, ended up just using some 4011 tape and one Oring, working just fine.
Oxy 3 / Jeti DS-16
Old 12-24-2012, 10:08 PM   #13
matthewcornell
Pics please?
matthewcornell is offline        Reply With Quote
Old 12-25-2012, 07:42 PM   #14
MiataJohn
I finally ended up using some hook and loop with the o-ring as insurance. Turns out if you use the o-ring alone, the ESC will slide out the front of the bird. Kind of a strange setup to me.
AMA 732104
Old 12-25-2012, 08:48 PM   #15
matthewcornell
I used the same solution :-) Thanks for letting me know.
Old 12-25-2012, 10:18 PM   #16
Ty89m
Think ill go that route on my stretch build
Oxy 3 / Jeti DS-16
Old 12-25-2012, 10:28 PM   #17
LVeillon
Never had the problem...Hemostats and 5 seconds...All Done!
Logo 600-3D Carbon & 600SX, HeliJive's, Kontronik, 700-45
Scorpion 4035-450 MKS BLS & Torq Servos Spirit Pro FBL, BK Jeti
LVeillon is offline        Reply With Quote
Old 01-02-2013, 10:29 AM   #18
corrosionate
I just stretch the crap outta that sucker and hook the single band on there. My YGE60 will still slide in and out fairly easily, but not so easy that it falls out. I dont think its squeezing the esc too tight at all. Maybe a thicker esc would though.
Plastic flies better :-P
corrosionate is offline        Reply With Quote
Old 01-03-2013, 05:14 PM   #19
ziper_it
+1
ziper_it is offline        Reply With Quote
Old 01-05-2013, 01:15 AM   #20
pilot4fn
I pull the rubber band thru the frame with bent zip-tie. Don't want to use metal tools to possibly nic the rubber band.
MiniProtos Carbon with Low FBL, MSH 2580kV, YGE 60A, Mini V-BAR
Kyosho Concept 46VR with ASP46, GP750
Walkeras: Genius CP Brushless, V100D03, V120D02
Futaba T8FGS
pilot4fn is offline        Reply With Quote
