| Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion |
Anyone running 693se and an 18t piniom for 2200-2250hs,and if so do you like it?
Trex 700DFCHV,helijive,vbar 5.2 pro Goblin 500 bls 153,bls 251,jive 100,pyro 600-12 20t pulley,mini v 5.3 pro Rockin TP 65c and 70c and Futaba 8FGS. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Pilot Brandon J. |
She's a big girl for 690mm blades.
Cyclic is extremely quick on 710mm, no worries there. |
Right on man,ill get a set of 713se's as i like how the se flys over the standard. Did mikado set a max recommended hs for this heli too?
I think its 2100rpm.
Steve To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. #1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251 #2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256 |
I wouldn't even flinch at spinning 710's at 2300.
The head is well, and truly way overbuilt. Hell, I plan to spin 750mm blades at 2100 ! |
#6 |
Yeah i got ya,just thinking about the lipos lol,can you set 2200 in vbar as your max hs with a bone stock setup and still have gov headroom/good performance or do we need to step up to 18t.
#7 |
you would need 18tooth to be that high with proper headroom yes. Thats with stock bundle yes.
#8 |
If the XX800 can swing 810mm at 2200 im sure the XX700 will have no issue with proper gearing.
(´・ω・`) ギルティクラウン (´・ω・`) (´・ω・`) (´・ω・`) |
