| Everything Else for Sale - Non Heli Related *No Commercial Ads* NO FIREARMS! |
hi guys i have up for grabs today a tonnage of new in packs Traxxas Jato 3.3 Parts, over $300 worth of stuff at less than half the price, and with free shipping, everything listed and in the pics for the first $150 shipped free for all. thanks and have a Merry Christmas
TRA5544 Bellcrank Posts jato (2) $3.49 TRA5521 Front & Rear Suspension Pin Set jato $5.99 TRA5516 Roll Hoop/E-Z Start Plug Mount jato $4.99 TRA5247 Carburetor O-Ring and Seal Kit TRX $3.19 TRA5276 EZ-Start 2 Complete Gear Set Complete $6.69 TRA4581 Glow Plug Lead Wire (Blue) EZ 1, EZ 2 $1.89 TRA4583 Jato 2.5 & 3.3 E-Z Start Wiring Harness $3.99 TRA5578 Traxxas Anaconda 2.8" Tires w/Foam $14.99 TRA5576R Jato Rear Anaconda All Star Wheel used (2) $21.99 TRA5582 Diff Gear Set Jato $7.99 TRA5579 Differential Gears Jato $6.99 TRA5581 Gaskets, Differential/Transmission Jato $1.45 TRA5514 Jato Front Body Mount $2.89 TRA5534 Rear Spacers, Stub Axle Carrier Jato $2.29 TRA5543 Steering Bellcranks Jato $4.49 TRA5119 Ball Bearings, 10x15x4mm (2) $4.49 TRA4146X Clutch Shoes/Springs (higher stall) $5.79 TRA5228 Cooling Head Protector TRX 3.3 Engines $2.49 TRA3147X Fuel Line (2 ft) $2.79 TRA5549 Fuel Tank Rebuild Kit Jato $2.79 TRA5593 Jato Primary Shaft and One-Way Bearing $15.49 TRA5136X Differential Oil Kit 10K, 30K, 50K opened $13.99 TRA5245X Tuned Pipe Coupler & Exhaust Deflector $2.99 TRA1666 Silicone Shock Damper Oil x2 (30 Weight) $3.58 TRA3232X Super Duty Long Glow Plug $4.15 TRA4976 Wheelie Bar Wheels & Axles $2.79 TRA5546 Tuned Pipe Hanger Jato $1.79 TRA5536 25 Degree Caster & Steering Blocks L & R Jato $3.99 TRA5556 Aluminum Slipper Pressure Plate & Hub Jato $5.99 TRA5530 Front Bulkheads, Upper & Lower Jato $6.99 TRA5518 Front Shock Tower Jato $3.99 TRA5149 Front Wheel Aluminum Spacers (4) Jato $2.29 TRA5562 GTR Shock Rebuild Kit Jato $3.99 TRA5555 Jato L&R Rear Stub Axle Carriers $3.19 TRA5517 Jato Rear Shock Tower $3.79 TRA3956 54T Spur Gear Jato $2.79 TRA4611 Ball Bearings 5x11x4mm $9.98 TRA5552X Slipper Clutch Rebuild Kit Jato $7.89 TRA1654 Stub Axle Pin & Collar: B,S,H,E, Jato $1.79 TRA5464 shock boots (2x2) $4.98 TRA5559 mounts suspension pin blocks $2.99 TRA2055 traxxas 2055 high torque servo new $18.29 TRA5261 Air filter insert foam $2.00 Traxxas GTR complete shock set new (4) 1 used $30.00 Yeah Racing complete Bearing Set (19pcs) For Jato $14.00 RC Screwz Traxxas Jato Stainless Steel Screw Set $23.99 and some decals for $free
hello my name is frank, and I'm an r/c addict |
anybody out there?
hello my name is frank, and I'm an r/c addict Last edited by electrodude71; 01-03-2013 at 03:41 PM.. |
one more bump
i have a jato 3.3 loaded with less than a gallon through the engine meticulously tookin care of i'll throw in for $400 shipped for all. theres over $450 in parts alone.
hello my name is frank, and I'm an r/c addict Last edited by electrodude71; 01-03-2013 at 03:01 PM.. |
#5 | |
its all about 4 months old, the latest and greatest model #5507 TRA5507 Traxxas Jato 3.3 2WD Truck RTR w/TQi 2.4GHz $400.00 everything that originaly comes with it in the original box PLUS TRA3232X Traxxas Super Duty Long Glow Plug $5.15 DYN2027 Dynamite Big Daddy Aluminum Fuel Filter $4.99 RPM80322 RPM Traxxas Jato Wide Front Bumper Black $9.99 RPM80722 RPM Front Suspension A-Arms (Black) Jato $7.99 RPM80752 RPM Rear Suspension A-Arms (Black) Jato $7.99 TRA5542X Traxxas Aluminum Drag Link set Jato $11.99 TRA5523G Traxxas Exo-Carbon Mid Battery Cover jato $3.79 TRA5547G Traxxas Exo-Carbon Fuel Tank Cap Jato $3.19 TRA5527G Traxxas Exo-Carbon L&R Dirt Guards Jato $12.49 TRA5515G Traxxas Exo-Carbon Rear Battery Cover Jato $5.19 TRA5524G Traxxas Exo-Carbon Receiver Cover Jato $3.49 TRA5551X Traxxas Jato 3.3 Steel Driveshaft Kit $32.99 Pro-Line Bow-Tie 2.8" (30 Series) Off-Road Truck Tires Front on traxxas all star rims. $27.95 Pro-Line Bow-Tie 2.8" (30 Series) Off-Road Truck Tires Rear on traxxas all star rims worn down tread.$27.95 DTXC2045 two Duratrax 7.2v 2500mah nimh batteries $32.00 INTT7915 Integy Graphite Brake Disk Set Jato $11.99 TRA5263 1.75 oz bottle of Traxxas Air Filter Oil $3.49 TRA1666 Traxxas Silicone Shock Damper Oil 30 Weight $1.79 Hot Racing dual disc brake mod set installed $37.88 Complete set of turnbuckle rods and ball ends Extra fuel line Extra air filter set and all the stock original parts
#6 |
sold
