Old 12-20-2012, 12:17 AM   #1
Ty89m
Default Programming ESC.
So I'm not sure which way to jump at this point. I'm running a 1300kv motor using the stock YGE. Those using Skookum units, should I run through all the wizards before programming the esc? I see a throttle/governor setup wizard, but know I also have to program the ESC with the TX and/or programming card.
Also, should I program with the TX first and then use the programming card to change settings, or should I just use the program card right from the start? I plan to use gov store, but at this point just want to get everything programmed to get me far enough along to test the motor, and make sure it's spinning in the right direction before hiding the motor wires up front.
What settings should I be changing if running 6S?
Mini Prôtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready
Mini Prôtos 6S - DS92A+/DS95i, SK540, YGE60
Ty89m is offline        Reply With Quote
Old 12-20-2012, 08:09 AM   #2
rossk
Setup the fbl.
Then setup the esc with the prog card, don't worry about tx programming.
You can do the full programming of the esc and the the gov store setup in one go.
If the motor spins backwards, it's a minor inconvenience to swap, but you have a 50% chance of getting it right first go, I'm about 80% lucky in my builds do far.
The recommended settings are on the MSH manuals and that's all I use.
Minicopter Diabolo - Kosmik 200 Cool, Pyro 800 Comp
MA Whiplash - Kosmik 200, Pyro 700
Protos500Stretch-YGE90+3226-900 Protos500-YGE80+MVVS950 ProtosMiniStretch-YGE60+2025-1360
MSH Brain Spektrum DX8
rossk is offline        Reply With Quote
Old 12-22-2012, 09:29 AM   #3
spykez
I cheat, I use the receiver that came with the DX8 and just figure out which way the motor spins at the start of the build then label the wires. I use coloured heat shrink wrap.
Prôtos mini's - trying desperately not to hit the ground...
spykez is offline        Reply With Quote
Old 01-07-2013, 02:35 AM   #4
cpmboy
Originally Posted by rossk View Post
Setup the fbl.
which manual?
All begins (Jun 2011).......
Solo Pro V2, Trex 450 Pro, Walkera QR Ladybird,
Blade 450 3D,DJI F450, MCPX V2, WL Toys V911
Next project:
MSH Mini Protos, 450 Airwolf
cpmboy is offline        Reply With Quote
Old 01-07-2013, 06:45 AM   #5
rossk
One of the ones in the download section(bottom right) of this page
http://www.msheli.com/Home.aspx
