| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
I have the 600SX bundle with JR12X Tx....MKS 970's on the cyclic, 990 on the tail....
And using the MIK4022 Carbon Servo Arm, 20 mm, JR And with 100 CW/CCW with the Mini V setup menu My questions are: When I apply full left/right rudder, using the arm hole distance specified in the manual, it appears as if the rudder pitch deflection has exceeded 90 deg. ....when looking at their combined relative pitch angle with full deflection... I don't think this is right....... Was going to reduce the pitch slider ends...even though there is room without binding at the extremes that I described above...I mean if you have more than 45 deg. deflection/tail blade...that's the extreme I guess I should move in a hole on the servo arm.....even though there is plenty of room on the pitch slider.... Thanks for any insight. |
Don't do this without flying. You can get weak tail if you reduce tail limits. Vbar shows this on tail optimizer. Do pyro on both sides with ending hard stops. Then determine if tail limits are too much or not.
T-REX 600 EX [ Pyro 700-52M | Scorpion Commander V 130A OPTO | VBar 5.3 Pro | BLS255HV & BLS256HV ] LOGO 600 SX [ HKII-4225-500KV | Scorp. Commander VI 130A OPTO | VBar 5.3 Pro | BLS255HV & BLS256HV ] |
On both of my 600's. 16mm hole. I am using between 100-110. I have .5 MM space between the tail hub and box at full deflection. I don't worry about blade pitch, the more pitch the better right?
Mind you that too much pitch in the tail blades can stress the tail rotor and reduce its performance significantly.
LOGO 400SE: ICE75, 500MX, DS510M+DS650, VBAR 5.3 PRO, EDGE 473, KBDD 72.5 LOGO 600SX: JIVE 100LV, HKIII-4025-1100, BLS451+BLS251, VBAR 5.3 PRO, EDGE 600, EDGE 95 |
How much space do you have between hub and tail box at full throw? I have always set up my heli's to get the maximum travel. I assume the VBAR does not ever comand that much but it is there if it wanted to. What HS are you using? I am 1600-1800 on the SE and 2100-2350 on the SX with great tail hold on both.
#6 |
Guys on my 3d i use 105 tail bladeso n the SX is there a need for 105 or 95 are ok??
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A |
#7 | |
http://helifreak.com/showthread.php?t=477019
#8 |
bavci, I follow your thread on Vbar forum and if you ask me you should not need full deflection to stop a small input left or right. I believe your problem is binding somewhere in the tail.
#9 |
I'm not aware of any changes that were made the would result in using 95 on a SX if you were using 105s on your 3d. I'm planning on using 105s when I get my SX as I liked the feeling of 105s better on my 6003d.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. #1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251 #2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256 Last edited by sgrim80; 12-24-2012 at 09:01 PM.. |
#10 | |
YOu have the 105 with stock tail??
#11 |
I don't have an SX yet. I had Quick UK grips on my 3d and I was running 105s and liked them better than 95s. I'm getting a SX as soon as I sell off my 600 3d cf airframe and I plan on running 105s on that because from what I understand its ok to do so on a 600SX because the tail hub was upgraded.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. #1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251 #2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256 |
#12 | |
#13 | |
My understanding is that the tail setup in the VBar should be used to setup the limits to keep the tail from binding in each direction not to set deflection or pitch. Different servos may have different amounts of travel. I use servo arm kit MIK4258 there is no need to change the distance on the servo arm. On the set you are using MIK4022 if I remember correctly the tail should use the 14mm hole on the arm which I believe is the inner most hole. If you have the tail servo centered and the pitch slider arm at 90* at center then you should adjust the travel cw/ccw to give it total throw without binding. As long as there are no large discrepancies between the two directions you should be fine.
Can't means "Don't want to" Align T-Rex 450 Pro VBar 5.2 Mikado Logo 600SE VBar 5.2 |
#14 |
"On the set you are using MIK4022 if I remember correctly the tail should use the 14mm hole on the arm which I believe is the inner most hole."
Yes, Mik 4022 on the inner hole....as per the manual. MSK BLS990 servo centered, pitch slider centered, with tail pushrod adjusted to give ~2 deg. pitch to counter torque..... But, using total throw, each tail blade's pitch is greater than 45 deg. Seems too much. Adjusted it, using the Mini-V S/W, such that they are just < 45 deg. each.... I'm within the adjustment range.....like 90(left rudder) and 95(right rudder).... Hopefully, that will be a good starting point...and can go from there. |
