Old 12-20-2012, 03:18 PM   #1
Rob43
Default Koby 40 - no tones on power-up
Hey fellas - can't get my new Koby 40 to emit tones when starting up. I am convinced my setup is correct.
Miini Vbar
ESC to Rx B port
Connected to motor (also tried with no motor connection - no error code blink)
Vbar is otherwise processing signals correctly
Tx set up per the instructions
I get a solid red light
I tried reversing throttle channel - no change
I tried reducing Trav Adj and Increasing Trav Adj - no change
Tried pressing button - no response.
Any suggestions?
= R
b43 =
Team Compass Support
Rob43 is online now        Reply With Quote
Old 12-20-2012, 03:32 PM   #2
Wh1teAfr1can
try what i suggested to your other post or try plugging it into a receiver directly. and test that
Team Kontronik
Team minicopter
Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256
Wh1teAfr1can is offline        Reply With Quote
Old 12-20-2012, 04:07 PM   #3
Rob43
Thanks for the suggestion. I tried your first suggestion. No change. Only thing I have is BEC output coming from the Koby. Servos function corrrectly. Push button does nothing. Tried reversing switch on Tx - no change. No ideas on my end. Never had this with Jives on Vbar.
Only other thought I had is to plug it into another Vbar setup with it's motor and attempt to program on another Vbar and see if it works or not.
= R
b43 =
Old 12-23-2012, 12:11 AM   #4
jhheli
Post your v bar file and what is your radio settings....and the negative faces up toward the mini v ? that should work, but try another port.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
SAB USA, KONTRONIK, PRC, CANOMOD, PULSE ULTRA
jhheli is offline        Reply With Quote
