Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 12-20-2012, 06:45 PM   #1
pas2knut
Default Loving my Nano CPx with pjacq BL kit
I just received my BL Kit from HF Member pjacq the other day. After flying this thing for three days I'm so glad I made the change. The kit put together by pjacq is awesome and very easy to install. The nice thing about his design is if I break the pins on the main frame. I can just buy a new frame, and remove braces and spacers from his design and put them on the new frame. It's a two piece construction. The first on both sides are body support pieces to make the frame rigid after removing pieces to install the motor. The second are spacers for the servo so the motor will spin without rubbing.
Thanks pjacq for a great design.
Gaui X5/AR7200BX
Nano CP X BL
pas2knut is offline        Reply With Quote
Old 12-20-2012, 08:46 PM   #2
mixfisto
Can you show us a pic?
mixfisto is offline        Reply With Quote
Old 12-20-2012, 09:32 PM   #3
bondkiller
+1
bondkiller is offline        Reply With Quote
Old 12-20-2012, 09:43 PM   #4
TeeJayShelton
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
The more I learn the more I realize I don't know
2x T-Rex 500, T-Rex 250, 2x MCPX
AMA#965241
TeeJayShelton is online now        Reply With Quote
Old 12-21-2012, 05:28 AM   #5
maG69
maG69 is offline        Reply With Quote
Old 12-21-2012, 06:49 AM   #6
pas2knut
Pictures have been added.
Gaui X5/AR7200BX
Nano CP X BL
Old 12-21-2012, 09:07 AM   #7
kingmeow
How's the total weight?
kingmeow is offline        Reply With Quote
Old 12-21-2012, 09:33 AM   #8
pas2knut
Spacers .75 grams according to the designer.
Gaui X5/AR7200BX
Nano CP X BL
Old 12-21-2012, 09:43 AM   #9
Miracle Boy
Errr, I can't see any pics???
Blade mSR / Blade mSRX / Blade mCPXv2 / Blade 4003D (not brave enough to fly it yet!!)
Miracle Boy is offline        Reply With Quote
Old 12-21-2012, 09:48 AM   #10
profilefan
I'm so jealous, mine is lost in the mail somewhere....
And I agree its a great design!
Trex 500 Pro DFC
Blade 450x (Next-D Scorpion 8)
Bl Mcpx (HP06V2/ HP03T), Bl Mcpx (TA915/ HP03T)
Bl Ncpx (HP03SPE/ HP02T)
profilefan is offline        Reply With Quote
Old 12-21-2012, 02:24 PM   #11
catpainkev
My BL Nano arrived in good time...and now it's in a christmas wrapping paper prison under the tree....release date 25/12/2012.....
catpainkev is offline        Reply With Quote
Old 12-21-2012, 03:16 PM   #12
Fooferdoggie
You should have used the world ending excuse to get it early. amateur.
Fooferdoggie is online now        Reply With Quote
Old 12-21-2012, 03:27 PM   #13
NCcraig
His wife wouldn't have bought that excuse!
Team Newb pilot
BL mCPx (HP06V2 motor/HP03 tail),130X with HP08 motor,Trex 450 Pro V2 (KDE450XF motor,iKON),Trex 500 ESP (KDE500XF motor, iKON),DX7, AMA# 966513.
PM me about mCPX & NanoCPX BL conversions.
NCcraig is offline        Reply With Quote
Old 12-21-2012, 08:38 PM   #14
pas2knut
Hope the post office get's it's act together, and you get your kit. It really went together well.
Gaui X5/AR7200BX
Nano CP X BL
Old 12-21-2012, 08:48 PM   #15
pas2knut
You've got PM.
Gaui X5/AR7200BX
Nano CP X BL
Old 12-22-2012, 01:36 PM   #16
Bladecpnitro
[QUOTE=pas2knut;4548863]I just received my BL Kit from HF Member pjacq the other day. After flying this thing for three days I'm so glad I made the change. The kit put together by pjacq is awesome and very easy to install. The nice thing about his design is if I break the pins on the main frame. I can just buy a new frame, and remove braces and spacers from his design and put them on the new frame. It's a two piece construction. The first on both sides are body support pieces to make the frame rigid after removing pieces to install the motor. The second are spacers for the servo so the motor will spin without rubbing.
Thanks pjacq for a great design.[QUOTE]
Does this kit use the stock 3-1 board?
Where do I order one? I just got the Nano CPX yesterday and love it but want a tad more power as always.
DX 7, EXI 450 FBL GT-5, HK 250 FB Quark, Nano Brushless 16500KV 125mm boom
Bladecpnitro is offline        Reply With Quote
Old 12-22-2012, 01:56 PM   #17
pas2knut
Yes it does use the stock 3n1 board. You can just PM pjacq and ask if he has any of his kits available.
Gaui X5/AR7200BX
Nano CP X BL
Old 12-22-2012, 07:48 PM   #18
pas2knut
I took mine apart to capture better pictures of the design.
Gaui X5/AR7200BX
Nano CP X BL
Old 12-22-2012, 07:58 PM   #19
Bladecpnitro
Thanks. That's just a brushless main and stock tail right?
Old 12-22-2012, 08:09 PM   #20
pas2knut
Yes and it performs well!
Gaui X5/AR7200BX
Nano CP X BL
