Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 12-22-2012, 08:56 PM   #21
vertico
Where and when will these be available?
130x - 450x - Goblin 500 - mCP X BL - mCP X HP08s Double Brushless - Trex 600n
vertico is offline        Reply With Quote
Old 12-22-2012, 09:30 PM   #22
lespaulrob
I love this design...can you just buy the spacers by themselves? I have the AD mild kit, but would rather use those spacers which seems to eliminate the need to cut out the frame and glue the carbon fiber stuff on. Well done!
_________________________________
MSRX, 130X, DBL Nano CPX, 450X, DX6i
lespaulrob is offline        Reply With Quote
Old 12-22-2012, 09:43 PM   #23
bondkiller
+1
i sent pjacq a PM asking about it, waiting for a reply....
bondkiller is offline        Reply With Quote
Old 12-22-2012, 10:16 PM   #24
Finix
Looking at the pics the frame is still cut at the stock motor supports and the front frame member has been cut away - possibly it saves the gluing the carbon fiber.
Blade mCPx V2 / Blade 130X / Blade 300X
Spektrum DX8
Phoenix
Finix is offline        Reply With Quote
Old 12-22-2012, 10:19 PM   #25
TheMark
I'm digging the design. Still would love to see a completely new frame made specifically for BL
TheMark is offline        Reply With Quote
Old 12-22-2012, 10:36 PM   #26
pas2knut
Yes the frame is cut out, but it does eliminate the need to glue carbon pieces.
The best bet is to PM pjacq about availability.
Gaui X5/AR7200BX
Nano CP X BL
pas2knut is offline        Reply With Quote
Old 12-22-2012, 10:38 PM   #27
TeeJayShelton
Mine is enroute
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
The more I learn the more I realize I don't know
2x T-Rex 500, T-Rex 250, 2x MCPX
AMA#965241
TeeJayShelton is online now        Reply With Quote
Old 12-23-2012, 12:46 AM   #28
pas2knut
Originally Posted by TeeJayShelton View Post
Mine is enroute
Gaui X5/AR7200BX
Nano CP X BL
Old 12-23-2012, 05:14 AM   #29
Miracle Boy
Originally Posted by pas2knut View Post
You've got PM.
Thanks for the PM of the pics. I can now see the pics in the main thread.
It's an interesting design, which provides good, solid mounting for the servos plus no need to CA carbon parts which will be hard to remove if you need replace the main frame.
My only reservation would be about the additional weight that the kit adds.
Very cool though!!
Blade mSR / Blade mSRX / Blade mCPXv2 / Blade 4003D (not brave enough to fly it yet!!)
Miracle Boy is offline        Reply With Quote
Old 12-23-2012, 06:15 AM   #30
Bladecpnitro
Does anyone have a vid up of this kit flying?
I'm really liking my Nano but would like it to have just a little more zip.
In stock trim it does flip pretty quick but I don't think it will keep up tic tocs, maybe tiny rainbows.
I also like the idea of a new frame for the brushless motor.
DX 7, EXI 450 FBL GT-5, HK 250 FB Quark, Nano Brushless 16500KV 125mm boom
Bladecpnitro is online now        Reply With Quote
Old 12-23-2012, 07:31 AM   #31
TheMark
One more ?, how is the geometry of the servo arms?
Old 12-23-2012, 08:57 AM   #32
pas2knut
Good, no issue with rubbing the side of the servos.
I did trim the canopy a little to much to make sure I didn't have any rubbing. I used a hole punch a little to aggressively.
Gaui X5/AR7200BX
Nano CP X BL
Old 12-23-2012, 12:06 PM   #33
TheMark
Thank you!
Old 12-24-2012, 08:24 PM   #34
Bladecpnitro
What are you guys soldering with? I just had 1 heck of a time replacing a Tail FET in my brand new Nano with my bulky soldering iron. I bought the Nano on the 21st with 4 stock total packs, flipped it the 22nd and never got through my 4th pack early that morning.
Shortly after I had started flipping it it dropped to the ground and the tail motor wouldn't shut off.
It turns out the tail motor wires were resting right on top of the right aileron servo shaft that's turning every time the servo moves. I think it wore through the enamel on both wires and shorted out the tail circuit and blew the tail FET.
I found a FET from one of the kids old walmart mustang remote control cars.
That thing was loaded with FET's. I lost the 1st one, destroyed the 2nd one and like to have never got the 3rd one installed.
But its working now, I just forward flipped it in the house a dozen times are so and flew it inverted a while. I like it. I love its reset button, which is walk over and grab it and reset it and go again.
Old 12-30-2012, 03:55 PM   #35
xpcm
i use hakko fx888
Good bang for the buck
.2mm bent conical tip for smalls
Real thin solder helps also
xpcm is offline        Reply With Quote
Old 12-31-2012, 03:16 AM   #36
TeeJayShelton
Thumbs up
Got mine installed tonight did a little test hover and couple punches in the dark. Worked perfectly. Everything was a good fit and all supplied. I was nervous beforehand about the small solder job but that turned out to be pretty easy as well. Ty to both seller and op for the pics and feedback on the kit. Very happy with how rigid it is without having to glue it together. It was a very fast and painless install. Looking forward to playing with it a little(super busy day) tomorrow.
AMA#965241
Old 12-31-2012, 04:43 PM   #37
Canuk
Got mine on order.
Looks like a very easy kit to install and the way the frame is braced there is no gluing.
Nano CPX, Blade 450 3D, DX6i, Phoenix Sim
Canuk is offline        Reply With Quote
Old 12-31-2012, 05:32 PM   #38
balbs
So is this a frame upgrade or a full frame + brushless motor + esc upgrade? If it's just for the frame, can I use the astroid-design mild kit with it?
balbs is offline        Reply With Quote
Old 12-31-2012, 08:53 PM   #39
pas2knut
It's a complete mild kit.
Frame upgrade
Brushless motor
ESC
Everything was included to convert the Nano to brushless.
Gaui X5/AR7200BX
Nano CP X BL
Old 12-31-2012, 08:55 PM   #40
pas2knut
Originally Posted by Canuk View Post
Got mine on order.
You are going to love this, I guess you will be selling those new brushed motors.
Gaui X5/AR7200BX
Nano CP X BL
