Old 12-20-2012, 07:28 PM   #1
jcflyer
Default Power Jive and MX700
Anyone here ever use this combo? I have a power jive 120HV and want to use it with the Align MX700 510kv motor???
Helicopters Don't Fly - They Beat The Air Into Submission
Trex 550 V2 Trex 550 V2.1 Stretched
Trex 700 V2 - BlackShark III Project
Minicopter Diabolo
jcflyer is offline        Reply With Quote
Old 12-20-2012, 07:43 PM   #2
Blink 182
just enable ksa mode :-)
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Blink 182 is online now        Reply With Quote
Old 12-20-2012, 07:44 PM   #3
jcflyer
What is ksa mode?
Minicopter Diabolo
Old 12-20-2012, 07:48 PM   #4
Blink 182
700mx may run odd without KSA mode enabled, this mode ensures that it runs problem free, your manual will tell you more about ksa mode :-)
(´・ω・`) ギルティクラウン
(´・ω・`)
(´・ω・`)
(´・ω・`)
Old 12-20-2012, 07:49 PM   #5
jcflyer
Ok thanks.
Minicopter Diabolo
Old 12-21-2012, 09:15 AM   #6
Wh1teAfr1can
for a Jive it is mode 10. it reduces the amount of timing and PWM changes the Jive can make. this is for Low inductance motors. the Align 700mx motors and KDE XF and Hacker motors all fit into this category.
Team Kontronik
Team minicopter
Diabolo Kosmik 200, Pyro 750 - 560kv, HC3X, BLS 255/256
Gaui X5 Kontronik 100 lv, Beastx
Wh1teAfr1can is online now        Reply With Quote
Old 12-21-2012, 10:04 AM   #7
Stolla
As to the above, but if youre confident and can ar you can test without ksa, some work non ksa and then you will have better performance, hard pitch pumps from hover is a good test, if it works fine then it should stay fine.
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
